- Jan 21, 2021
- 257
- 1,091
- 911
- New Orleans, LA
- Website
- www.oraclelights.com
- Bronco
- Base
We wanted to share something new we just dropped at ORACLE Lighting — the Vega 7 Series LED Pods, officially unveiled at this year’s SEMA Show. We designed these to compete with (and honestly outperform) some of the biggest names out there, while keeping the price point way more reasonable. They come in two setups: LED+LED and LED+Laser, and both absolutely rip in terms of light output.
The LED+Laser version clocks in at 676,900 candela with a projection distance of over 2,700 feet — so yeah, it’s bright. Like “two football fields past where your current lights stop” bright. One of the coolest parts about the Vega 7s is the Active Cooling System — a small built-in fan circulates air through the rear fins to keep temps stable even during long use. That means no thermal dimming and way longer LED life. We also made these super versatile to mount anywhere. The beam pattern is horizontally symmetrical, so you can flip them upside down or right side up without changing the beam angle. They also come with snap-on blackout covers (included free), and optional amber or yellow lenses for fog/snow setups.
If you’re into details: they’re IP69K rated, run OSRAM BOOST-HX chips, and use Deutsch DT connectors. Basically — no weak points.
Here’s the full rundown and preorder info: https://www.oraclelights.com/products/vega7
And if you want the full SEMA write-up, the blog post goes deep on the testing and design side: Introducing the ORACLE Lighting Vega 7 – The Next Era of Off-Road Illumination
Would love to hear what you guys think!
