Hooke RoadĀ®
Lux Sponsor (Level 2)
Hooke Road
CA
www.hookeroad.com
1. New Arrival! Half Roof Rack with 3 Steel Cross Bars $269.99
https://www.hookeroad.com/products/...or-6th-gen-ford-bronco-4-doors-hardtop-b8937s
This rack features 4 slot holes in each crossbar for securely tying items with straps.
2. Hot Sale! Half Roof Rack with 3 Aluminum Cross Bars $299.99
https://www.hookeroad.com/products/...lf-roof-rack-21-23-ford-4-door-hardtop-b8905s
This rack features top-facing T-slot channels that accommodate standard 8mm nuts, allowing you to secure items using T-slot nuts.
Dantastic
Daniel
Lake Saint Louis, MO
www.youtube.com
OBX Sas Bronco, Mazda CX-5
I really like this rack and having ability to remove the roof panels still. Having lettering that could be confused with "HOOKER DAD" is.... well.........unfortunate
Maybe instead of having ducks left on your rig, you’d have dolla bills tucked discretely in your tailpipe.
derichio02
Bo
Southern California
Bronco Badlands, Maverick, Tesla M3, F250 Tremor
@Hooke RoadĀ® Do the brackets have a liner or something to protect the hart top from marring? I have a painted top so would like some separation there.
Hooke RoadĀ®
Hooke RoadĀ®
Hooke Road
CA
www.hookeroad.com
I guess you need something like rubber pads. But we don't provide.
murphtron
T
Berkeley, CA
2023 Badlands, 2013 Toyota Highlander, 2000 Miata
I have this rack and the mounting pads are lined with rubber to prevent scratching the hard top. It works well. I got mine used on this forum
derichio02
Bo
Southern California
Thanks for the update. I wonder why @Hooke RoadĀ® says they don't come with them.
murphtron
T
Berkeley, CA
Luckylat
RI
1999 Expedition, 2013 VW Wagon, 2023 Wildtrak
I have and use both the Ford Factory rack and the Hooke 1/2 rack.
I use the Factory rack for ski season to mount my ski racks and use the Hooke 1/2 rack for summer so I can take off my top panels and also carry any beach/camping gear.
My Hooke 1/2 rack came with rubber pads to protect the top.
I also purchased the following Track Mount Tie Down Anchor at Amazon for the Hooke Roof Rack which are very useful to tie down any gear.
Found at Amazon - M8 Heavy Duty Ring Shaped Eye Bolt, Stainless Steel T Bolt Eye Nut Tie Down Rings. They fit into the channels of the crossbar, but I had to grind the T-bolts a little for them to fit/slide into the channels of the crossbar. They easily adjust/slide to the width of the gear you are carrying.
Link: https://www.amazon.com/Anchor-M8-1-...i=B0CG9ZCFWC&ref_=pd_basp_d_rpt_ba_s_2_t&th=1
Raybj
Ray
Milford, Ct
24 Bronco Wildtrak Sasquach 2dr
What about the 2 door?
tourproto
Portland, OR
2004 BMW 330i, 2022 Bronco BL 4DR
What are the tradeoffs between the version with aluminum cross bars and the one with Steel cross bars? From what I can tell there is a load difference, and a weight difference, but overall very minor. Just curious why they have 2 versions and the tradeoffs between them.
GroovyGeek
Boyan
'23 Bronco BD
tourproto
Portland, OR
@Hooke RoadĀ® ?
