FourHorses
Four Ford Horses and an Expedition
2021-2024 BRONCO 17"X 8.5" METHOD WHEEL KIT - OXFORD WHITE
Product Link: https://performanceparts.ford.com/part/M-1007K-M1785W
MSRP Price: $1,875.00
Part Number: M-1007K-M1785W
  • Ford Performance Parts partnered with one of the most recognized names in the Off-Road wheel industry, Method Race WheelsĀ®, to develop and certify this Off-Road Wheel Kit exclusively for the Bronco
  • Designed for 2021-2024 Bronco applications
    • Does not fit Bronco Raptor
  • Kit Includes:
    • Set of 5 Method Race WheelsĀ® 703 Bead GripĀ®
      • Oxford White Finish
      • Bead GripĀ® technology engages tire bead for increased grip at low tire pressures
      • Hub-centric fitment specific to Bronco
    • 5 TPMS Sensors and Activation Tool
    • 5 Snap-in center caps with embossed METHOD Bead GripĀ® logo
  • For matching black lug vehicle kit see: M-1012K-BR
  • This wheel and lug nut combination requires a Thin Wall Socket for installation/removal
  • Diameter: 17"
  • Width: 8.5"
  • Offset: +35mm
  • Backspacing: 6.20"
  • Center Hub Bore: 93.25mm
  • Bolt Pattern (PCD): 6 x 5.5"
*Tires not included*
Ford Bronco New: Oxford White Method Wheel Kit from Ford Performance Parts M-1007K-M1785W_V6
Ford Bronco New: Oxford White Method Wheel Kit from Ford Performance Parts M-1007K-M1785W_V7
Ford Bronco New: Oxford White Method Wheel Kit from Ford Performance Parts M-1007K-M1785W_V5
Ford Bronco New: Oxford White Method Wheel Kit from Ford Performance Parts M-1007K-M1785W_V3
VirginiaHeritage
Frank
ā€˜25 Bronco HE
  • Kit Includes:
  • Diameter: 17"
  • Width: 8.5"
  • Offset: +35mm
Looking at the lug nut and valve stem holes (design and placement) up close, I wouldn’t swap my OEM Heritage wheels for these if you gave them to me for free.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Interesting….I’ve never seen white wheels on Iconic Silver…I kinda like it.
911braptor
Dan
boston
bronco raptor bmw x3 M40 porsche 911
No thanks! I had white wheels on a sports car many years ago. What a pain in the ass to keep clean.
BroncoDC
Washington DC
These would work on a 2025 bronco too right? It says 2021-2024 not sure why 2025 is excluded unless they just didn't update the listing?
Rough Rider
2018 Mustang Convertible
25's have a new TPMS frequency I believe
BroncoDC
Washington DC
Wow. You are spot on.
  • Frequency Change: The 2025 Ford Bronco utilizes 433 MHz TPMS sensors, unlike the 2024 and earlier models which employed the 315 MHz frequency.
  • Reason for Change (Speculation): This shift is possibly driven by a desire for global standardization, as 433 MHz is the frequency used in many other parts of the world, including Europe.
  • Compatibility: Due to this frequency change, older TPMS sensors from 2024 and prior Bronco models will not be compatible with the 2025 Bronco.
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
2024 Bronco Everglades 4dr
Everglades
  • Kit Includes:
  • Diameter: 17"
  • Width: 8.5"
  • Offset: +35mm
While I like Method the company, those wheels just look wrong on the Bronco.
