MRTperformance
Plymouth, MI
www.shopmrt.com
2024 Ford Bronco
Hey Bronco6G fam —
Just wanted to give everyone a heads-up that MRT’s Annual Sale is live, and that means discounts across the full lineup of Bronco exhaust systems – including:
  • Ford Bronco Save BIG with the MRT Annual Sale! 32
    Trail Rated – balanced tone, daily-drivable
    King of the Hill – aggressive growl, no drone
    GOAT Series – loud and proud, for the bold
These are handcrafted, mandrel-bent, American-made systems designed specifically for Bronco. Whether you're looking to wake up your 2.3L or 2.7L with more personality, or get something trail-ready that won’t rattle your fillings, there’s a solid option here.
You can check out the full selection at www.shopMRT.com
Sale runs through September 2nd
If anyone has questions on sound levels, drone, install tips, or clearance for aftermarket bumpers, feel free to drop them here — happy to help out where I can.
Stay loud
P.S. Save even more when you use the promo code MBC10
BluebroncoNC
Stroppe
2025 Stroppe Bronco & 1977 Bronco
Stroppe
I have totally enjoyed mine. It has traveled with me onto my 3rd Gen6. Has held up. Would buy another if I ever manage to destroy it, somehow.
Figmo
Figmo
Frenchtown, MT USA
Suzuki Samurai, Bronco 2Dr WT, Gladiator Rubicon
When you say “performance eight“, I’m assuming that’s on a scale of one to 10?
Where does the stock exhaust fall on that scale?
And how did you arrive at that number?
Woody146
Matt
Chevy Silverado
Would like to hear/see some sound clips of them if you have them.
  • Like
Reactions: JC-
MRTperformance
MRTperformance
Plymouth, MI
www.shopmrt.com
2024 Ford Bronco
Yes, when we say “performance eight,” that’s on a scale of 1 to 10, with 10 representing the most free-flowing, least restrictive exhaust setup possible.
We rate the stock Bronco exhaust around a 3 on that scale. It’s designed by Ford to meet a wide range of comfort and sound-level expectations, which naturally introduces a fair amount of restriction in the name of quietness and emissions compliance.
At MRT, we define performance in terms of exhaust flow — the less restriction, the better the potential for performance gains, especially under heavy throttle. Our straight-through resonators are engineered to offer the same high flow as our muffler delete setups, with a bit more tone refinement. So when we rate our systems closer to an 8, it reflects that significant increase in flow capability over stock without compromising durability or drivability.
murrman
Sean
Toledo, OH
2024 2 Door Black Diamond
I'm potentially interested in the Trail Rated exhaust (axle back). What I'd like to know, however, is if there's quantifiable data to support any positive or negative affects the exhaust would have. While an improvement in the sound is nice, I care more about whether there are any performance increases (or decreases) and/or if it has any affect on gas mileage (positive or negative).
MRTperformance
MRTperformance
Plymouth, MI
www.shopmrt.com
2024 Ford Bronco
Appreciate the interest — the Trail Rated axle-back is actually our most popular system for the Bronco, and for good reason.
From a performance standpoint, the system improves exhaust flow by reducing backpressure, which can help your turbo spool slightly quicker and improve throttle response. While the gains aren’t drastic, they are noticeable, especially when compared to the restrictive factory setup.
We don’t publish dyno numbers for this system, and here’s why: dyno results can vary widely based on factors like temperature, humidity, altitude, and even the specific dyno used. More importantly, modern vehicles like the Bronco are tuned very precisely from the factory. Simply adding bolt-on parts like an exhaust or intake doesn’t automatically unleash massive power unless the ECU is recalibrated to recognize and optimize those changes.
That said, our goal with every system is to maximize flow using sound exhaust engineering principles. Even without a tune, improving flow is never a bad thing and helps lay the groundwork for future performance mods.
As for fuel economy, we’ve had some customers report modest MPG improvements. However, it’s worth noting that once you can hear your exhaust, you're often tempted to be a bit heavier on the throttle — which is fun, but not always fuel-friendly. If you drive it like you did before the upgrade, you may notice a small increase in MPG, which is always welcome on a big, boxy rig like the Bronco.
Let me know if you have any other questions — happy to help you find the right setup for your needs!
DaddyO
Jules
Austin, Texas
2024 Bronco 4D 2.7L Sasquatch
I am looking to improve performance on the trail and fuel mileage on and off the road. I am not a road racer and am not a lead foot. I don’t care what it sounds like. What’s your recommendation?
MRTperformance
MRTperformance
Plymouth, MI
www.shopmrt.com
2024 Ford Bronco
If your goal is to improve trail performance and fuel efficiency — and sound isn’t a concern — I’d recommend the Trail Rated Turndown system.
This setup increases exhaust flow and is designed with off-road functionality in mind. The turndown tip is tucked neatly behind the rear bumper, offering excellent clearance and protection from trail obstacles — no low-hanging pipes to worry about.
crenca
Southern New Mexico
Thanks for admitting this. Too many consumers believe, and too many aftermarket suppliers explicitly state or silently go along, the idea that it is a simple equation: Less back pressure/more flow always = more HP/performance/mpg.
MRTperformance
MRTperformance
Plymouth, MI
www.shopmrt.com
2024 Ford Bronco
Absolutely — we see this a lot, especially on smaller-displacement engines where people assume jumping up to a 3" exhaust automatically means better performance. In reality, that can actually hurt performance by eliminating too much back pressure, which causes exhaust gases to tumble and disrupt flow efficiency.
Exhaust design is all about balance — it’s not always “bigger equals better.” The ideal setup varies depending on engine size, intended use, and how the vehicle’s ECU is tuned.
BluebroncoNC
Stroppe
Stroppe
And you get rid of that heavy half keg of a muffler Ford has chosen to tuck under the back end for something the size of a shoe box.
MRTperformance
MRTperformance
Plymouth, MI
www.shopmrt.com
2024 Ford Bronco
Lost me at checkout.
Just to clarify, shipping is free, but there is a small handling fee at checkout.
That said, I can offer you two options:
  1. Use promo code MBC10 from the original post to take a bit more off the sale price.
  2. Or give us a call directly at 734-455-5807 and we’ll be happy to waive the handling fee for you over the phone.
Let us know what works best for you — happy to help!
