4x4
Tucson AZ
Escort and Escape
BRONCO AUXILIARY LIGHTING KIT- MODULAR FRONT BUMPER
Product site: https://performanceparts.ford.com/part/M-15200K-BL2
Upgrade your Bronco with the Ford Performance Bronco Raptor fog light upgrade kit. This kit includes everything needed to upgrade your Bronco, including the RIGID® fog lights and custom wiring harness allowing use of Raptor lamps on non-Raptor Broncos.
  • Fits all 2021-2025 Broncos with modular bumper
  • Kit includes:
    • RIGID® fog lamps
    • Factory fog lamp brackets
    • Factory fog lamp bezels
    • Bronco Raptor bumper end cap assemblies
    • Bronco Raptor bumper rear covers
    • Factory wiring jumper harness
    • Custom wiring harness
    • All fasteners required for complete installation
NOTE: This kit is only for use with the Ford Performance Modular front bumper, available as standard on Raptor, optional on non-Raptor or available on our site as M-17757-BM for the non-Park Aid version or the soon to be released M-17757-BMP with Park Aid.
NOTE: This kit is designed to be used with the factory Auxiliary switches. A universal switch is not included. If you do not have the factory aux switches, you can upgrade your Bronco with the soon to be released Ford Performance Bronco Auxiliary Switch Kit M-9100-BR or determine the best switch solution for your application.
Ford Bronco New: Bronco Auxiliary Fog Light Kit (OEM Raptor Fog Lights for Modular Front Bumper) M-15200K-BL2_V3 (1)
Ford Bronco New: Bronco Auxiliary Fog Light Kit (OEM Raptor Fog Lights for Modular Front Bumper) M-15200K-BL2_V2 (1)
Ford Bronco New: Bronco Auxiliary Fog Light Kit (OEM Raptor Fog Lights for Modular Front Bumper) M-15200K-BL2_V4
basham1988
Tom
North Ridgeville, OH
'24 2Dr 2.7l Badlands
I really wish these were plug and play with a factory fog light switch rather than needing to be tied into an up fitter or stand alone switch.
They even might be? But from the product description, they don't appear to be..
DarthLincoln
Chuck
Northern California - Contra Costa County
1999 BMW M coupe, 2023 Ford Bronco Badlands 2dr
yeah they appear not to be compatible with factory fog light switch harness as the description says. The factory fog light harness on non-raptor vehicles (shown below) only has 2 wires/pins in the connector:
Ford Bronco New: Bronco Auxiliary Fog Light Kit (OEM Raptor Fog Lights for Modular Front Bumper) 1753223215214-cd
But the image of this kit appears to show that they dont combine the two lights on each side before their connector - so the jumper harness on each side have 4 wires/pins in their connector.
Ford Bronco New: Bronco Auxiliary Fog Light Kit (OEM Raptor Fog Lights for Modular Front Bumper) IMG_2335
All the combining of wires happens in the custom long wire harness that you connect to the Aux switch.
j_marinelli
Spring Branch, TX.
Looking at the picture up close and personal it looks like its exposed wire ends that are made to tie into the AUX switches
Ford Bronco New: Bronco Auxiliary Fog Light Kit (OEM Raptor Fog Lights for Modular Front Bumper) Screenshot 2025-07-22 174115
They probably did it this way as the fog light switch method requires forscan to program it.
HalfmuleFarmer
Thomas
2025 Badlands
Seems like $1300 might get you a superior aftermarket solution from Baja Designs or Diode Dynamics … just saying. At half that price I’d consider it.
BearPatrol
23 Bronco
I got my 3 sets of Baja Designs Squadrons for $850 from 4x4truckleds. I'm pretty sure I waited for a sale, but still... These Raptor lights are a ripoff at that price.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
$1,290 for sub-par fogs? You can get a Baja Designs kit for less $$ which will outperform that kit
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Yes that's how they are designing the kit. The description even says you need upfitters.
That hidden wire we all LOVE to use isn't even something Ford officially seems to support. They even did away with it on 2025+ vehicles (not sure why, as it was part of a harness they used on multiple builds).
Whiskey Bizness
Franklin, TN
2025 Bronco Badlands Sasquatch, 2025 F150 Tremor 402A.
100% would go with a a Baja Designs or Diode Dynamics kit from @4x4TruckLEDs.com instead.
And, correct, the 2025 doesn't seem to have the unused fog light harness behind the bumper like the previous years did. It kind of sucks that Ford did away with it.
Andrew Bynum
Los Angeles
21 Two Door OB Sas V6 AMB
There’s a reason it’s been 4 years and I’ve not gone the Baja Designs route. I don’t want my Bronco looking slapped together. This solution offers a clean factory appearance; the aftermarket light options look like the lights were an afterthought in the mod bumper because, well, they are.
BluebroncoNC
Stroppe
2025 Stroppe Bronco & 1977 Bronco
Stroppe
Price has come down. Back when I knew I was getting a Stroppe edition I had the Ford Parts department guy look up the cost of a Raptor set to fit the bumper. He quoted me $1,600.00.
wjtinfwb
Bill
Destin FL
Jeep GC, Excursion, Focus ST, Subaru Crosstrek
Beggsie
2024 Bronco
Yup, no thanks Ford.
JoeyBones81
Ben
Greenville, SC
Ford Bronco
This is the most interesting part of the description:
“ If you do not have the factory aux switches, you can upgrade your Bronco with the soon to be released Ford Performance Bronco Auxiliary Switch Kit M-9100-BR …”
also, are the end caps only different JUST to mount these fog lights?
