HalfmuleFarmer
Thomas
2025 Badlands
I know a bunch of people are probably going to hate on this post for a few reasons, so first, a bit of background, and a few disclaimers: I’m a new owner of a MY25 2DR Badlands, with the ‘upgraded’ B&O 12-speaker audio system. I’m also a retired music industry guy, who’s spent time in the recording studio and the mixing booth with lots of artists over the last couple decades. I’ve got three music projects in production right now, and over the last year I’ve listened to new mixes from these albums hundreds of times on a half dozen different audio systems (from studio monitors to very expensive home systems to small, but good-sounding bluetooth setups). I listen carefully looking for detail, clarity, distortion, muddiness, separation, etc. I know what the recordings I’m working on *should* sound like from hearing the masters directly. And like you all, I also have many classic recordings that I know like the back of my hand, some of which are the go-to staples of listening tests at high-end audiophile shops. I was eager (and worried) to hear what everything would sound like in my new vehicle.
Like a lot of prospective new Bronco buyers, I wondered if the OEM audio system was garbage and a waste of my money that I’d just end up replacing, or whether the enhanced B&O offering was decent, adequate or maybe even not that bad. Any answer to this must address two subjective points: Does the system reproduce recordings faithfully (enough)? Does it perform decently at middle to higher output levels?
Last caveat: Any music producer will tell you that building a satisfying auto sound system is a challenge, simply because you’ve got an irregular space and lots of different absorbent and reflective surfaces. The main listener is decentered while the speaker system is usually symmetrical. Different types of music or even different recordings within the same genre might require some radically different EQ to sound their best. Also, playing compressed digital audio means you’re usually starting out with some quality loss already. Streaming will be more compressed and lossier still, but hey, welcome to the way most people get their music in 2025. My preference is to play files downloaded to my phone via cable and CarPlay.
So, here’s one man’s review:
My simple, short answer is that for most normal music listening situations, the MY25 12-speaker B&O system is fine. More than fine, honestly—maybe even bordering on good. The first test was listening to a bunch of newly-released and highly produced recordings, each with a lot of dynamic range. Did it hold the highs and mids without sounding tinny or thin? Yes. Did it reproduce bass and lows with a satisfying solidity? It does. Can you actually feel the low end sub through your body at mid-volumes? You can. I don’t notice any distortion or muddiness at the middle of the output with the volume set at 15-20. It’s adequately loud in this range. Unless you’ve got the top off or the windows wide open (which would make a silly test of any vehicle’s sound system), I would say 18-20 is about as loud as you’re going to want to play anything just driving around town with the windows up.
Second test was harder to reproduce stuff, like some boomy hip-hop and jagged industrial, electro. These types of recording will drive speakers harder and demand a different type of cone response, as they often combine very unforgiving edgy highs and near subsonic thumping lows. Speakers hate square waves and a lot of these tunes are full of them. But these too sounded fine on the B&O system. Not exactly muscular, but solid. Not ragged or overdriven. Crisp highs, tight resonant bass, good feel from the sub in the body of the driver’s seat. I can even feel it lightly in the foot pedals.
Last test is a few classic albums long regarded as studio production high-water marks. Can the B&O system make them sound as rich and deep as they do on most quality stereos? I’d say almost. One of the producers I work with would call the Bronco’s system a bit “flat”—meaning it doesn’t add to or color the tonality of the sound at all. It doesn’t warm it up. Ironically, this is how studio monitors should sound, faithful to the recording and not enhancing it. “Flat” is good in the studio where you want to hear how a track really sounds, but most home systems juice things a bit and give you more EQ options than the Bronco. Personally, I don’t find this problematic. Maybe other people do, and I appreciate that. A few more options would be good. But I did make some simple setting adjustments that I think helped quite a bit: I have my tone settings set with treble about 50%, midrange at about 60% and bass about 70%. I’ve toggled back and forth between stereo and surround quite a bit (which are essentially EQ and speaker presets), and I’ll say, surprisingly, that surround improves the overall quality noticeably.
Final thoughts: I can understand how the B&O system doesn’t meet some Bronco owner’s needs — just like how suspension, wheels, bumpers or headlights are something a lot of people run out and replace on their brand new vehicles. This is NOT a booming system that you’re going to light up a block party with. It’s not trying to be powerful, but very few car audio systems that come straight from a dealership are. The car stereos that sound much better are in cars that are much quieter. The Bronco itself is a loud ride, so there’s a lot going on in one’s ears when behind the wheel of this machine, especially in a soft top or with the roof off. I’ve got a hardtop and the new sound-deadening headliner seems quite good. I can’t speak to soft/no roof sound, but really, one’s expectations of great sound in a vehicle without a roof should be very, very modest (the aftermarket is for you if this is what you’re after). My Bronco is also a 2DR, and while that shouldn’t be especially significant, it does mean the rear pods are a bit closer to the driver and the overall interior space is smaller with less soft surface areas. I’ve owned 5 European cars, from Land Rover to Volvo to Mercedes, and I’d say the MY25 Bronco sound is comparable to or better than any of the manufacturer systems I’ve owned. If I was going to drop thousands of additional dollars on my already expensive new toy, the sound system would not be close to the top of my list. Would I describe it as outstanding or amazing? No. But it’s fine. More than fine. Good even. Cue up something recently remastered that sounds good already. Enjoy it. You’re driving a 4x4. Here’s to rocking in the free world. Peace out people!
glashaus
Tom
Houston, Texas
2015 Silverado 2500, 2025 Bronco Badlands
Thanks for the expert review. I have a 25 Badlands on order that will be built later this month, the Lux package was something that I was going back and forth on, I am glad that I decided to add it
12th Man Ag
Drew
Houston, TX
2025 Bronco
I don’t know anything about what you said, but I agree that the 2025 system sounds pretty good to my 54-year old ears. I think 8-10 volume is plenty around town with the windows up. Top off and windows down and 20 was plenty for me.
Go_UL_Cards
Wyatt
The Villages, FL
2024 4 Door Soft-top
I don't have the B&O system but the 7 speaker system was bashed on many threads. I upgraded dash speakers, went to bigger pods, replaced subwoofer with 8" and changed some forscan settings. Mine also sounds much better than what i've been reading about. I've decided to hold off an any amp upgrades - at least for now. Changes from Ford? Or different level of satisfaction? WIth top off and volume at 15/16 i'm plenty happy.
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
Good review.
Not a music industry guy myself... but I did spend over a decade in the broadcast industry, so I have worked with professional audio gear and audio engineers. Luckily for me, most broadcast audio engineers are musicians and music producers who couldn't quite make a living in the music industry, so I got to learn a lot from them.
I agree. I was pleasantly surprised by the almost "reference-like" sound in the 2025 audio system especially. A lot of audio systems in cars these days try to add a little bit of extra "sauce" to it because... frankly... that's what a lot of people like. But I was happy they didn't try to do too much to it, and did a reasonably faithful reproduction.
Overall the 2025 system is MUCH improved over the 2021-2024 B&O system. Whomever worked on the audio system updates for 2025 (Ford? B&O?) did an excellent job. A sound system upgrade was the very first thing I did on my Bronco. But if I was buying a 2025 Bronco w/ B&O, I don't know if I would have even taken the time to do an upgrade. Definitely would not have been anywhere near the top of the list.
B22-2023
Houston
My first impression looking at the length of the post was, jeez is this another review of a D’Agostino monoblock? Like I’m reading Stereophile.
It’s just a Bronco, man.
But my takeaway is more positive - good for 2025! I’ll always put $$ into/on top of my rig’s OEM audio, but maybe not as much if I had ‘a 25. Great news for buyers that Ford figured something out after what we’ve all been through.
And thanks OP, forgive my sarcasm - but in a longer than usual post you really conveyed good info.
HalfmuleFarmer
HalfmuleFarmer
Thomas
2025 Badlands
Thank you, brother. The B&O system was just something I worried about pre-purchase, and there’s really know way to know until after ... So I thought other folks in my position may appreciate it. Cheers!
CalvinT
Calvin
Phoenix, AZ
Thank you for an excellent review. I have the stock system in my 2023 and it sounds fine to me. It doesn't match what I have at home, but that's not it's purpose.
There seems to be a line of thought that anything that's stock factory equipment must be sub par and need improvement, no matter what it is.
I used to feel a need to "improve" my cars, but now I do a lot of critical thinking and research before making changes. Often I decide not to make changes.
That doesn't mean that those who have specific requirements can't benefit from changes. But too often people make changes just because everyone else is doing it. And they don't understand the full implications of what they're doing.
I'd love to hear a system that someone has "improved" playing the type music I listen to. I'd like to see if I can hear the difference, and if I can, what would the difference be? And I'd like to know what kind of music they listen to that makes them feel the stock system is inadequate.
ON3BadBronco
Arin
Glendale, CA
2025 Ford Bronco Raptor
I couldn't disagree with you more the B&O is absolutely garbage. One it's not a B&O system it's a Ford paper speaker crap that had a def B&O sound guy come in and tune the speakers. Any dodge Harman or Alpine system sound a million times better then the BS B&O system in not just the bronco but all of the ford cars. And yes I own a bronco with the B&O system.
tourproto
Portland, OR
2004 BMW 330i, 2022 Bronco BL 4DR
Great review.
I have the base audio system in my 22 Badlands (or whatever came in the High package offered at the time). To me, the sound is good enough to my 60 year old ears.
BUT
I am totally open to upgrading the speakers when the factory ones go out. And the only reason I say this is I just replaced my 21 year old Harmon Kardon speakers in my E46 BMW with mid-high-end speakers from Bav Sound. Best $400 I have spent on my bimmer. Even with the stock head unit, everything sounds way better.
But not 100% sure it would have sounded so much better if I had installed the new speakers in 2004 vs 2025. The OEM speakers were pretty tired, and when playing well-known tunes from my iPhone (wired connection), stuff just didn't sound great (again, even to my 60yo ears), so I took the plunge on new speakers and yup, made a great difference.
At some point, as long as I am on this side of the grass, I will replace the speakers in my Bronco. I do hope that when that time comes, there will be a company like BavSound that has a "drop in" speaker replacement for the Bronco, and I can just swap speakers in an afternoon and have instantly better tunes, even with the stock headunit.
