swamp2
And given how nearly all videos/pictures make any feature/obstacle/trail in any off roading discipline look way easier than it is IRL, even more impressive!
AARDVARK122
john
utah
2007 volvo xc70
I was at UBB too. But didn’t do anything as tough as you did. I think what is most impressive is that you did it with all that stuff on top of your bronco, making it super top heavy. 😂 Well done 👍
monsterfd
monsterfd
2014 raptor widebody 37s, 2018 raptor 2018 JKU 35s
You speaking the truth!
monsterfd
monsterfd
Yeah that definitely made it a challenge, it’s bad enough that for this, the raptor takes a different line than non raptors. By the way, is this you? I was admiring for a long while 😅
Ford Bronco My overland Bronco Raptor tackling Sliprock Gulch at United by Bronco IMG_8838
ONEBronco
Keith
Omaha, NE
2022 Bronco
How did you not tip over on this?
Ford Bronco My overland Bronco Raptor tackling Sliprock Gulch at United by Bronco 1741532100518-5l
monsterfd
monsterfd
Geometry. The steepest off camber point was 22°. Rattles the nerves but you won’t tip. The hard part is the chair and seatbelts don’t restrain well during camber, and you don’t want to lean on the door and raise your center gravity because the RTT is already doing that. If I started to get close to 30° I would reset for a new line
Felix808
SRV CA
Is this the tuck that had the tires farting air because it was so over loaded that I heard about?
monsterfd
monsterfd
troll much? :crackup:you mean the one that did sliprock on hard mode? i wasnt overloaded i was 15psi riding sidewalls without beadlocks
tourproto
Portland, OR
2004 BMW 330i, 2022 Bronco BL 4DR
Felix808
SRV CA
I do not. I was asking a? about what I heard & this example you provided seemed to match what I was told.
I run 10-11 PSI without beadlocks all the time. Only lost a bead once at 10 PSI
YMMV 🤠
monsterfd
monsterfd
YMMV 🤠
Nice. Did you ride all sidewall on a v notch at 10?
tourproto
Portland, OR
Really? I celebrated after conquering that! I didn’t buy it to mall crawl 😂
I go off-roading, but not rock climbing (at least not like that). I am not yet to the point of causing damage to my Bronco for fun.
It was an impressive run...
