Tricky Mike
21 Bronco
October 4th I set off to run the Rubicon with the Inland NW Bronco Club. I arrived at Airport Flat campground 10/5 and we started the trail 10/6. We finished 10/8. I didn't do the buggy stuff but I took as many of the hard lines as was reasonable and it performed very well.
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241006_141549619
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241008_152012089
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241006_161635701
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241007_221230120
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241008_190402126.MP
Tricky Mike
Tricky Mike
21 Bronco
Then we headed to Carson City, NV and on 10/9 we met up with a group to do some trail clean up. We recovered 2 abandoned vehicles. The rest of the week was spent at NV Super Cel. The rest of the club headed home but I had other plans.
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241009_233652584
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241012_184525774.PANO
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241010_173430502
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241012_010358288
Tricky Mike
Tricky Mike
21 Bronco
Then immediately afterwards I ran Slickrock. This was much harder and I shouldn't have been out alone, but I got through it.
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241013_195824638
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241013_211553241
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241013_201650757
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241013_213942629
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241013_200716564
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241013_214933600
Tricky Mike
Tricky Mike
21 Bronco
10/14 I ran Sourgrass. Very easy trail, out in back in about an hour. Then I headed down to Lodi to visit Wildhorses, where I loaded up on some goodies. BTW a 1G grill doesn't quite fit inside the roll bar halo...
10/16 I met up with a local with a 4dr and we ran Barrett Jeep Trail. This is where it all went to hell. I flopped on the gatekeeper. We decided to continue on, the damage was already done.
Unfortunately the Bronco electronics had other plans. I started to intermittently lose 4WD, then I had an ABS fault and lost all GOAT modes and lockers. Also it started raining pretty hard. We made it about 3/4 to the end and the Bronco had had enough and I was pretty defeated myself. So we turned back. His ABS also faulted on the way out! So we fought and clawed our way back out with frequent winching. After airing back up back on pavement all codes cleared within 2 minutes. Thanks Bronco!
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241014_164545790 (1)
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241014_170313134 (1)
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241014_214541442
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241016_152307537
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch IMG_20241017_184603
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241016_165601133
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch IMG_20241017_184555
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241016_171821831
Tricky Mike
Tricky Mike
21 Bronco
So at this point I'm not in the best head space so I drove back to Carson City and got a room for the night. I was intending the cut the trip short at this point.
A good night's sleep did wonders and I got the Bronco patched up in the morning. I let @popo_patty know I was back in for the Reno to Vegas 500 starting on 10/18.
The RtV500 was a new experience. I learned 100" is not an optimal wheelbase for desert bashing, especially as loaded down as I was. Without proper bumpstops my tires kept getting into my fenders and eventually broke all the clips on one flare.
We ended up cutting it 80 miles short after the Braptor blew it's 2nd sidewall. I had signal and jumped on FB Marketplace while we attempted to patch the sidewall with Gluetread for the second time. I found a guy 2 hours south that had a 37 on a F150 wheel and arranged for @JohnGalt to meet him.
The 2nd patch also leaked but held well enough for him to limp down there. Once we got to pavement and called it I went north instead to cut some hours off my return trip.
I pulled into my driveway on 10/21, completely exhausted. I averaged 13 mpg over the entire trip of 3258 miles. I often got 10-11 on the highway with the RTT up there. If there was any kind of crosswind it screamed like a banshee. IDK if that was the rack or tent but it made me never want to use it again.
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241017_165720004
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241017_172850929
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241020_020303675.NIGHT
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241019_234635403
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch 464013167_10235207596876623_535364719113204923_n
Ford Bronco 17 days, 3258 miles, 6 trails, 13 mpg, 102 hours seat time, 1 big crunch PXL_20241018_192158679.MP
RC Bronco
Rob
Kansas
'22 Ford Bronco, '97 Geo Tracker
Dude what a trip! Sorry you damaged your rig, but man what memories you created! And several badass photos to boot! Bravo my man!!
Toccoa
Isuzu Rodeo Sport
