0" Lift coils/struts availability?
jp9901
Jared
phoenix, az
22 ford bronco black diamond, 02 dodge dakota slt
I was wondering if anyone saw any simple replacement struts or coilovers that would not add a lift. I have a black diamond non sasquatch and am having a pretty hard time finding the actual specifications for mine aside from the part number. The bronco rides a little rough so I was hoping to go to some other coils but not sure I want to lift the vehicle as I like where its at now.
Just seeing if anyone has any idea if any are out there. Haven't been able to find it on google yet. Maybe its just not on the aftermarket quite yet?
rguest3
Raymond
Florida and Virginia
F-350, F-450, 23 Bronco, 24 Raptor, (2) 77 Broncos
Don't know of any Coil-Over replacement with "0" Lift???
The 4WP Coil-Overs are adjustable form 1-3.5" Lift. At least you could get your Bronco more level at the 1" Height. You would want to replace the Front and Rear though.
5280Bronco
Denver
I've heard that the badlands bilstein setup rides a bit better, and the non squash combo is only about .7 inches in lift. You may want to think about that setup as well. I know it isn't 0 lift, but it's better all around with minimal lift.
That's the direction im gonna go with my BD.
edgeflyer
2013 FX4
Yep, check your air pressure first. I run 32-33 lbs also.
Papa Smurf
Jax, FL
‘23 Bronco WT. ‘23 Maverick. Hybrid. '23 Rav4
I replaced my stock OBX non SAS with BL non SAS. The ride is markedly improved over the rough stuff. As far as lift goes, I actually got 1.5” on the rear somehow. The front has a spacer so the number is irrelevant. This measurement was the same day as installation and honestly, I’ve been too busy and lazy to remeasure after any settling.
jp9901
jp9901
Jared
phoenix, az
Yea, I had test drove a BL non sas before I ordered so I was surprised by how much better it rode. Might be a good way to go.
Thanks for the input on tire pressure, I will give that a shot too once I get my new wheels/tires.
Tcarp1
Travis
Newcastle, CA
2021 2 Door Badlands
Radflo makes a non lift and lift coilover option
jp9901
jp9901
Jared
phoenix, az
Interesting, radflo never came up when I was on google.,
I did air my tires down from 39 cold to 35 cold and that made a huge difference on the stock shocks.
