🛠 8/9 build week thread
Dirtyjed
Orangevale
05 Dmax, 86 FunRunnah, Tiyoda truggy, Honda shi
Tricky Dick
Dick
PNW
www.TD-Distributing.com
4DR FE A51 MIC
20210811
Blend 0793
ASM 795/896. <——what does this mean?
It means that a total of 896 vehicles are planned to go down the assembly line on 8/11 and that yours will be the 795th vehicle going down the line. The number above that is the number of Broncos that will built that day, near as I can tell.
So all vehicles on your blend date will have 2 of the same numbers and only one number is the actual assembly line number.
555 <- same for everyone who shares a blend date.
795/896 <- everyone on blend date has xxx/896
Where are you seeing this ASM number?
jmadsen
Josh
2012 F350, 2017 Explorer, 1945 Ford GPW, 53 C6
Original build week for 7/26. Bumped to week of 8-9 still waiting for window sticker to show up. No emails from ford so crossing my fingers.
7-13-20 reservation. 2 door badlands 2.3 L. MT. Non squatch.
Trav
PA
6.7 Powerstroke
Still no winder sticker, dealer is saying build date of 8/11. Hopefully get the window sticker here soon.
Brandon1282
Brandon
U.P. of Michigan
2020 JLRD, 2021 GMC 1500 AT4 3.0
On the upper right hand side of the window sticker to the left of the vin
Interesting. I didn't realize my status changed on the Ford tracker. I just found my window sticker through the bronco6g tracker.
So I went back to check the Ford status and I noticed I have a link to the window sticker on that page. Pasting for reference.
Mine did the same. Link took about 24 hours to generate a sticker. Try the order track tool on here.
Tricky Dick
Dick
PNW
Thanks. But it doesn't follow @mpeugeot 's theory that it's the number built that day, they aren't doing 1700 in one day.
Ford Bronco 🛠 8/9 build week thread Screenshot_20210804-073849~2
mpeugeot
Not with that attitude lol
That's the first one that I have seen that high. What date is that for blend again? Is it a Bronco? (It could be for a different assembly line elsewhere). I might add, this was a hypothesis which initially appeared to make sense. I could be completely wrong!!!
Tricky Dick
Dick
PNW
8/9, it's from my Bronco sticker. Dirtyjed a few posts up also shows 1700.
Big ragu
Aric
Ohio
Probably a bronco sport crashing the wrong thread
mpeugeot
Ahhh, I suspect I know what's possibly going on.... remember, initially everyone is assigned to a build week, then they break up the build week and I bet that the numbers are then spread out over that week.
Tricky Dick
Dick
PNW
Could be.
So I'm number 93 next Monday. I hope their morning coffee has kicked in by then.
RTLGarage
AJ
New Braunfels, TX
2021 Bronco (I also have a 1992 XLT)
mpeugeot
Could be.
It's my best guess and seems to be a reasonable explanation of why so many on the build week, I am sure that they are still spreading them out, but yours should be headed down the line just about the time the coffee kicks in. ;)
The 755/1700 worries me, as that means that only 44% of those are Broncos... how that will sort out is anyone's guess, perhaps they are assigning build days to the Broncos first and then the rangers.
