πŸ‘€ 42 Inch Tires πŸ‘€ RTR Fun-Runner
NORCALGXP
Sacramento, California
2017 Raptor
I am dating myself here, but I grew up when it was all about BIgfoot.
Twin Predator carbs, big 8-71 blower, first guy to use rear steer. Bob Chandler was a god on how you build a big ass truck. ;)
I know what you mean right with you.
SS Bronco
Shayne
Loomis CA
2021 Bronco , F600, F5, LJ20
That is going to last 10 seconds on a trail, but it looks good.
Why would you think that? Have you ever seen how amazing the broncos do with portal axles off road. If it wasn’t so expensive I would have them today.
hemiblas
Roger
Aurora, Co
2023 base SAS Bronco, 2018 Rubi JL and JLU
I should have gone through the list of upgrades. It does sound like they have done their research.
BAUS67
redneck
Central PA
And portals like the Ultra 4 4600s. 😁
I thought of something else I wanted to share in regard to this picture. Many posting here may know this already but for those that don't.......
If you look at the tie rod assembly used here, does it look familiar??? It may look familiar except for one aspect. If you look the bolt is supported from the top AND the bottom. This is known as double shear. and makes it almost impervious to bend/break. When you are using a rod end and moly/alum/billet/etc. shaft you really need to make it double shear because what will end up happening is you will just bend the bolt going through the rod end because there is nothing to support the stress. Problem is making the stock knuckle double shear.
My advice to anyone is to stay away from this "style" of tie rod fix. It may look cool but, it will fail. (Unless it is double shear as in the pic)
BAUS67
redneck
Central PA
Oh yeah, they have done their research. The portals have been much 1,2,3, this year in Ultra4 4600.
BAUS67
redneck
Central PA
Yeah, I am afraid of how much they are going to be. πŸ€ͺ The way I understand it, they, Weld 74, the ones who make the portals do not make the setup under the Broncs. Just the portal. I believe Titan maybe is how does the arms and setup. Weld 74 has just come out with a bolt on setup for a Jeep. don't know if they are going Bronco or not or just let some else do it.
Bronkers
Ben
Las Vegas, NV
2022 2dr Bronco
SS Bronco
Shayne
Loomis CA
I wanted this exact set up this spring. Was quoted 21k for the portal boxes and 18k for the rest of the front assembly. This doesn’t include the labor, rear end, tires, or body work.
BAUS67
redneck
Central PA
Was that a Fun Haver quote??
SS Bronco
Shayne
Loomis CA
No I didn’t know they where building it. 74weld, and the other parts from Gomez Brother Racing they build 4400 class cars
BAUS67
redneck
Central PA
Ford Bronco πŸ‘€ 42 Inch Tires πŸ‘€ RTR Fun-Runner 1667795232004
I was curious when seeing the By-Pass shock and the Coilover both. Found another pic and it looks like it they have moved the mounting points in this setup to make room for the By-Pass shock inside of the UCA.
The Ultra4 4600 class is only allowed a "single shock" setup.
Ford Bronco πŸ‘€ 42 Inch Tires πŸ‘€ RTR Fun-Runner bronco-4600-race-trucks-ultra4-ford-performance-10
OX1
jackson nj
59 Bird, 70, 74, 78, 79 Broncos, 84 LTD 331 w/Vortech, 86 Capri 5.0 turbo, 14 Stang GT, 17 Fusion Sport
I'm building a clapped out old bronco or buggy on mogs for that kind of coin.
BAUS67
redneck
Central PA
Them guys are a riot!!!!! Live coverage of KOH is never the same when they are on the air. Cool.
