Still awaiting delivery on my everglades. Question. Who took off their roof rails right away and why?
BlinkyLightMgr
BlinkyLightMgr
Awaiting mine too, assume they will remain on till summer.
Superthornbird
Superthornbird
I did, I love the look with it on, but the mid panel is not removable with the rack in place.
friethmiller
friethmiller
After about a month I removed the rack.. in order to add the extra seals to reduce the wind noise. Put all back together after that.
Skunkape24
Skunkape24
Just got mine last Friday night, I am going to wait until this summer....
Fillups
Fillups
I have Everglade pending order, but I removed the roof rails on my 2-door a couple months after purchasing. I liked the look but I had no plans to use them anytime soon and the reduced wind noise on highway made it worth pulling them off. I also was prepping to do ceramic coat at that time, and wanted to have the windshield plugs in place. I have it hanging on my basement wall, pretty easy to put back on if needed.
BMoreDogDoc
BMoreDogDoc
Took mine off over the summer as it was somewhere between a pain and impossible to get the panels off. Planned on putting them back on when the fall weather came in, but I never got around to it. The Everglades looks good with or without the rails.
Kiff
We are also still waiting for ours to arrive. We got the soft top with it so in the warm months we will not have the rails on so we can use the soft top.
Bronco luv
Bronco luv
I took mine right off:)
Bronco luv
Bronco luv
Let me know how your soft top does with wind noise on the passenger side … curious if snorkel causes more noise.
Kiff
@Bronco luv I do hear soft top flapping/slapping from what seems to be centering on the roof above the rear passenger seat and around the passenger side read window. I've never been in a 4 door bronco with soft top without the snorkel to know if that is where it always is. I don't notice it on the driver side so I suspect that the snorkel is causing the air to move that way.
phostman
@Bronco luv @Kiff There is a good bit of flapping from the air turbulence caused by the snorkel. I found a pretty cheap fix. 12" piece of Velcro with double sided tape on the horizontal bar right over each window. Then i had the hook side of the Velcro sewn on by a friend who is an upholsterer. $10 for Velcro and 2 cases of beer later, no more flapping at all. I still cant fathom the thought process behind the design of the top.
CitrusBronco
CitrusBronco
I took mine off, we want to be able to go topless.
TheWaterBronco
TheWaterBronco
Removed mine right away as well
phostman
Took off the roof rails the second I got home. I ended up buying a soft top for a steal so they wouldn't have been on much longer.
friethmiller
friethmiller
Update: removed mine, don’t think it’s ever going back on.
