Kant
I have a quick question: is there any issue with installing pillar lights on the Everglades since there is a snorkel?
friethmiller
friethmiller
Yes! You can’t on the passenger side
friethmiller
friethmiller
With that said, fabrication of a custom mount might be possible. I've got the same issue with mounting hood struts. There still sitting in a box on my workbench. Need to figure out a custom mount. These are good problems to have, I guess.
friethmiller
friethmiller
Hood Strut Discussion: Ok, I mounted the drivers side hood strut yesterday and started to look at the passenger side. Couple of things that I've determined so far: 1) the mount hole on the hood cannot be used. The top of the strut mount will hit the snorkel; 2) the bottom mount could be used depending where the hood mount is [re]positioned. I am currently trying to figure out if the top connection point on the hood could be moved an inch or so over and allow free travel for the strut in the original bottom mount/bracket. With where Ford placed the ECU and it's bracket, they've made it difficult but there might be just enough room. I'll report back in a few days...
Reactions: Kant
Kant
Kant
Thank you for the update!
friethmiller
friethmiller
FYI, I will post a new thread to show pics of my working IAG hood strut on the Everglades group.
Reactions: Kant
