FreddieLee
Also, is the Everglades (snorkel) safe in a carwash? Between hand washes, I usually drive my cars through a touchless carwash where it basically uses high pressure sprayers to clean the surface instead of those brushes that beat your car to death. Anyway, it occurred to me that water will probably get sprayed into the snorkel.
uncledoodoo
uncledoodoo
I'd probably move the plate to the front to keep water out
BMoreDogDoc
BMoreDogDoc
I moved the plate to the front after I took delivery… Do we think there is an ideal orientation for day-to-day driving?
FowlBronco77
FowlBronco77
@BMoreDogDoc I'd say front unless it's raining or something else in the air we don't want in the engine
BMoreDogDoc
BMoreDogDoc
Also the plastic pieces are surprisingly flimsy…
FreddieLee
FreddieLee
Very flimsy, and it does not sit flush against the snorkel. It needs a rubber gasket to seal.
FowlBronco77
FowlBronco77
@FreddieLee thanks for the heads up, I may get some gasket of some sort and put on there when it comes in.
