Hey19
JJ
Bethlehem
Awesome! That may have looked mellow to some, but I'm guessing that was fairly steep.
Erock
US
2018 F150 Alpine edition
Now, if I can get my girlfriend trained to spot that well, I can mall crawl just like Mr Gittin!
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
JHawk
Ray
Heartland, USA
Fusion Sport
what is a safe low pressure to run if the wheels do not have beadlocks? Safe as in not breaking a bead and going flat.
Smurph
66 Bronco, 76 Bronco, 2008 GMC SIERRA2500
I have routinely run interco tires 37x12.5R15 on 15x9 wheels at 8-10 psi and never had a seal break
BroncoKong Jr.
Andrew
Depends on the tire and the wheel width. 15 psi is generally safe but you might be good down to 10.
DukeofArmchair
Josh
VW GTI
Somewhat depends on the wheel and tire combination. A narrower wheel with a wider tire (within reason obviously) can help with keeping the bead seated. Some wheels have a little more agressive bead lip. I aired down to under 10PSI with Goodyear MTRs on cheap steel wheels.
Dads_bronze_bronco
DukeofArmchair
Josh
VW GTI
The second video made it look like they aired down somewhat; no idea what PSI.
Agreed, the right rear looked like it but if it was hanging on to a rock ledge with 1/4 of the tire width it would deform the tire pretty easily. We probably won't know unless they tell us šŸ˜
