Upgrading to HOSS 3.0 steering worth it?
Wild_Trak
Nick
Clackamas, OR
2022 Ford Bronco
is it worth upgrading to hoss 3.0 steering rack? do you have to have it programmed?
popo_patty
Caleb
Sacramento
2021 Bronco/1996 Jeep XJ/1957 FC-150
What kind of mods do you have and what do you do as far as wheeling?
I’d only recommend it if you’re running 37’s and do heavy rock crawling. Otherwise it’s overkill.
Wild_Trak
Wild_Trak
Nick
Clackamas, OR
2022 Ford Bronco
i am on 37s and with icon UCA's and icon coilers
popo_patty
Caleb
Sacramento
So with a lift and 37’s you definitely need to brace the steering rack. 74weld and Broncbuster both have kits. I run full BB setup on my 2.0 steering with 37’s and lift. It works fine for daily driving and moderate wheeling.
If you’re heavy in the rocks though and notice your steering rack loosing power or overheating then you need to upgrade to the 3.0. Main benefit of the 3.0 is the extra torque from the motor.
MLPAGANO72
New Jersey
I’m about to put a 2.5” RC lift on my SAS OBX. More then likely will put 37’s on it. This has been on my mind as well. Thanks for the suggestions.
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
Steering failure is not something I wana deal with...ever, so from my point of view? Ya worth it! To answer your 2nd question: YES!
Aliass24
NJ
I have a badlands with 315/70/17 recon grapplers on 0 offset wheels and SAS suspension, I drive only on pavement my question is should I add tie rod braces and steering rack bushings to help with breakage or am I ok. Thanks
chtucker
Kirkland, WA
FJ Cruiser
What is 1.0 vs 2.0 steering rack? I get the 3.0, but don’t understand the difference between 1&2
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
popo_patty
Caleb
Sacramento
The 2.0 is the standard rack found in most Broncos. I havnt heard of a 1.0 rack though. 3.0 is gonna have a little better of a housing and stronger motor over the 2.0 (think of hydro assist for hydraulic steering as a rough example).
chtucker
Kirkland, WA
FJ Cruiser
So my early 2021 Badlands and First Edition have 2.0 racks?
