broncoepic
broncoepic
Bronco Badlands Sasquatch
Are thos AR BALLS or something from 67?
These balls are neither from AR or 67. I purchased them (Tackform 20mm ball) from Amazon before anything was available and had to source hardware from ACE to make it work. I haven't checked on availability but I should get the AR version to clean up the install.
UNBROKN
Central Virginia
04 F-350 CC dually, 97 Infiniti QX4, 21 Bronco BD
I always love your videos and get excited every time you do another one. I drive a Black Diamond without front lockers. Can you talk about whether different obstacles need both or if you think rear only would be good. Maybe even try some obstacles with only the rear locker. Thanks!!
Headless Horseman
MD
2023 Badlands
Kicking off 2022 with a trip to Moab, UT to run the trails with my friends. I hope you guys enjoy this episode of us running the Steel Bender trail.
The badlands is more than a capable vehicle...great video...thank you!
broncoepic
broncoepic
I'm glad you're enjoying them and really appreciate the feedback. Majority of the time I engage the rear locker only. Choosing a different line and/or giving it the good ole bump makes a big difference. That being said, having a front locker does come in handy. The video below is of some in cabin footage from the Steel Bender trail that didn't make the cut. However, I wanted to share them with the hopes that it may provide some insight into the different situations where I'm using the locker/s out on the trail. This YT video is unlisted so it can only be viewed here.
UNBROKN
Central Virginia
That video is a huge help. No other video that I have seen shows anything like that. Shows how the rear locker is what you need to get over most of the terrain. Without a front locker, a little tiny bit more pedal may suffice or a little help from a friend.
broncoepic
broncoepic
I’m glad it helped and will look to incorporate more of these types of clips in the videos.
Itchysquatch
Luke
Vermont
99 4runner, 2014 E class
Love your videos, thanks for sharing!
luckys13
Todd
VW Atlas, Mini Cooper, Bronco
Great video so and so fun to watch. It made me want to go with you guys sometime!! What mods have you done to it? Its fantastic!
broncoepic
broncoepic
I’m glad you enjoyed watching it. Moab is amazing place to explore the outdoors. My list of mods can be found on Revkit.
