Has anybody got Auto Hold to work with ForScan?
Finbox
FL
KLR650
2023 Braptor
I have followed the cruise control, start stop thread, and made changes. I have the auto hold selection turned on in the big display, but cannot slide it to activate.
Just for clarification “auto hold“ I mean when you come to a stoplight press the brake, it auto holds and you can release your foot off the brake and the bronco stays still, this is totally different than stop and go auto hold
thanks for your time.
Noremac
Arkansas
2021 Bronco Badlands Sasquatch
yes, if you have it on that screen, you have to have your seat belt latched before you can actually activate it
Finbox
FL
KLR650
i’ve tried it with my seatbelt on, still cannot slide the slider to activate
Noremac
Arkansas
Which changes did you implement?
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
2023 Braptor
That would be super cool!
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Regular Bronco's DON'T have this feature correct? - Only Braptors? Or can this be activated in FORscan?
Ducati1098
No Broncos have it from the factory. Have to use forscan on all of them.
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
So does anyone know how to do this in FORscan? Any links would be great. I'd LOVE to program this feature into my Bronco!
Ducati1098
RoverDude
Maryland
2021 Bronco (First Edition)
I've done it on my 21 FE.
It works without any issues.
I surprisingly like it, it makes me feel like I have launch control at a stoplight.
Does not work for reverse. Only forward drive mode. FYI before you lose a door as you go back into your garage.
Finbox
FL
KLR650
I have done the following
  • BodyCM easymode, change 'Cruise Control' to 'Adaptive Cruise Control, Stop and Go'
  • ABS AsBuilt, changed 760-03-01 B*** **** to F*** ****
  • APIM easymode: Auto-hold [Enabled]
  • IPC easymode: Auto-hold [Enabled]
  • Menu option appears under Driver Assist, your door must be shut and seatbelt buckled to enable.
The Auto Hold on/off slider is there, but it won’t slide
thanks for your help
Ducati1098
Did you do a PCM relearn?
bcb1
Brad
Martinsburg, West Virginia
2017 BMW X5
ne13thdream
Crystal
Montgomery
Bronco 23 VB
I had this in my past car and LOVED this feature for traffic and car pool! Thanks for the heads up!
