13 inch wide tires on stock wheels
DewarT
Todd
Hard to say. I have read in a few other forums that the 37x13.50 fits with no rub, but I, personally, have not verified fitment.
can you tell me where else you have seen this posted? Been searching for this info. I have a ‘23 Raptor and it is screaming for wider tires on the factory beadlocks capable wheels.
my concerns include knuckle clearance as well as turning radius with everything under the fenders
Discount Tire
Arizona, USA
discountti.re
All Things FORD
rguest3
Raymond
Florida and Virginia
F-350, F-450, 23 Bronco, 24 Raptor, (2) 77 Broncos
I would go with whatever the Tire Manufacturer recommends for wheel width size. This is usually a Range of widths. One might say 8-11" for instance.
Rocketship41
Denver
2023 Bronco Raptor , 2022 Model S, 2022 R1T
I can confirm what does rub. I installed Nitto Trail Grapplers, 37 12.50 17s on the stock raptor rims. And they rub at full turn, which is a bummer. Wish I did some research before buying them. Nittos TGs are at lease 1.5 inches wider than the BFGs AT Ko2s.
I'm pretty bummed, as I did not think the Nittos would be to big. They are to wide.
Hope this helps someone.
wanna1
Andrew
2013 Ford F150 Platinum 4x4 2022 Mach E
I got some Borla .75" spacers so that I can use my OEM forged headlock wheels with 39x13.50 BFGs. That will be the equivalent of a +15.
I have a set of 38x13.50 Falken RT1s on my RaceLine 9x17 +25 forged beadlocks with no rubbing. I have a 1.5" body lift.
wilbersk
Sean
2023 Bronco Raptor
I was about to order these for my Raptor so thank you! I’d like to avoid spacers if possible.
Rocketship41
Denver
Ended up with BFG Mud Terrains KM3s. 37 12.50 17s ... Fit perfectly on stock wheels.
DewarT
Todd
Do you have pictures of the stock wheels with the 13.5 tires and spacers on your Raptor? Would be interested in seeing the spacing between the UCA and tire as well as clearance at full lock in both directions.
Separate question- you only have the body lift, no suspension mods for 39s? What are your thoughts on the body lift? Does it make for a big gap at the bumpers or visible gap in the wheelwells?
