ZROADZ slider / step installed
zedster
Las Vegas
'21 Bronco 2 dr Badlands SAS, '22 F150 PowerBoost
FYI
The brackets you need to mount these if you don't have a badlands are hard to find.
Mine have been on backorder for 4 weeks with no word on when I can expect them.
Got my steps almost 2 weeks ago.
What is the difference? Very interesting.
Gofar
Doug
Carson Valley
21 Bronco 4dr base sas 2.7
Base models don't have a factory Rock Rails and the brackets that mounted the rails.
You need those brackets.
zedster
Las Vegas
Mine came with the brackets built into the step/sliders. Bolts were also built in that go into the pinch welds.
kbobber
Kevin
Tiburon, CA
VW Touareg & Atlas
Installed the Zroadz sliders. Great quality and an easy mod. They are heavy so help from a buddy wouldn't hurt. I did notice 3/4 of the factory slider nuts were only hand tight and a couple were almost off the bolt. It would be a good idea to check the factory nuts.
Look great. Do you mind taking picture with the doors open to see width?
DoubleD
Doug
Crown Point, Indiana
Chevy
FYI
I have had my brackets on order through Ford since 12/29. Still no word on when I will get them. Unreal
@BadBlueBronco
Kc
Los angeles
2021 Bronco Badlands
FYI
I have a set im willing to sell but I am selling them with the badlands rock rails
zedster
Las Vegas
I am not understanding what the folks are taking about when they say they have brackets on order. From Ford or from Zroadz.? Zroadz slider/steps have the brackets built in.
zedster
Las Vegas
I just looked at my rock rails that came with my Bronco and those brackets are built into the rails as well.
Bybotie
Bybotie
Nigel
Edge ST, 2021 Mustang Mach1 HP, 2021 Bronco
The brackets where the horizontal bolts attach to the body are only on the factory equipped trucks. Without them there is no place to bolt the rails to the body. You would only have the pinch weld bolts holding them on.
da_jokker
Jeep Wrangler JKUR
What??? So i dropped my Factory steps (WT) now that real rock rails are out. These are in my #1 #2 choice.
Are you guys saying that without factory rock rails you can't mount after market body rails?
Someone take a picture of what they're talking about.
If this is true then this sucks. Nobody should be selling rock rails that require factory rock rails in order to install.
NORCALGXP
Sacramento, California
2017 Raptor
Ford Bronco ZROADZ slider / step installed 1643128633682
Bybotie
Bybotie
Nigel
The 4 door has 2 brackets that are not on the truck unless you ordered it with factory rock rails. The 2 door has 1. Pictures...
Ford Bronco ZROADZ slider / step installed 20220201_155200
Bybotie
Bybotie
Nigel
