- Josh
- Apr 25, 2022
- 379
- 536
- 179
- Salem Ohio
- 2022 Bronco 4-door
- Badlands
Zone Offroad ZONF1220 For 2021-2022 Ford Bronco 2" Front 1" Rear Lift Kit
Zone Offroad 2021 Ford Bronco 2in Fr 1in Rr Lift Kit - ZONF1220 Lift and level your 2021 Bronco with a first-to-market upgrade that will increase tire clearance without compromising ride quality or drivability. The 2" Spacer Lift Kit (F1220) is available from the Zone Offroad Products lineup for non-Sasquatch models, meaning it's compatible with the 2021 Base, Big Bend, Black Diamond and Outer Banks Bronco. Features and Benefits: - Lifts and Levels Stance - Maintains Superior Ride Quality and Drivability - Clearance for Large Aftermarket Wheel/Tire Packages - Top-Mount Design for Simple Bolt-On Installation - Works within Operating Limits of Factory Upper Control Arms - Does Not Require Strut Disassembly* *Strut must be slightly compressed to rotate the top hat. The 2" Spacer Lift Kit successfully adds clearance without sacrificing drivability by working within the factory suspension parameters. Your 2021 Bronco is already aggressive in appearance and powerful in performance. All it's missing is a suspension upgrade for an even better stance. Bolt on this 2" Spacer Lift Kit and let loose on the streets, trails and beyond! Please Note: This lift kit from Zone Offroad is not designed for use on Bronco Sport models. It is designed for use with Base, Big Bend, Black Diamond and Outer Banks models. This lift will not fit the Badlands, Wildtrak or First Edition models or models equipped with the Sasquatch package as it will not fit the Bilstein shocks.
Fitment: 2021, 2022 Ford Bronco
