Zip Tied Washer Bottle
KnoxGnater
Nat
Knoxville, TN
1934 Ford Roadster Pickup, Bronco Badlands
I think the engineering term you are all looking for is “janky”.
As in, “that filler is ‘janky’ as fuck. Think we aught to put a zip tie on it.”
As and Engineer, can confirm.
Busyboy19
Boston
F150, OBX Bronco
Was this missed at deliver or at final QC?
Ford Bronco Zip Tied Washer Bottle 82FA5025-5A80-431D-98AD-C28ADC20F148
Captain nSANEo
Grand Strand, SC
Jeep Wrangler
Unfortunately, that is meant to be there 😅
cazimi
MA
2021 Bronco 2dr
Busyboy19
Boston
F150, OBX Bronco
Brnco2.7
Dexter Michigan
1976 Bronco
Yes Yes that's what I want to do on a 2021 $50k car ..... carry a a hose and a funnel in the back in case i want to fill the washer fluid up at a gas station
That's just brilliant bubba!
Come on. You just zip tie a funnel to the zip tie!!
Deleted member 12876
Guest
In the Old Days these handy zip ties would have been bulky, corrosion-prone hose clamps. There’s many locations in every car where zip ties are used to hold things in place.
I’m not feeling the hate like most of you are…
No there’s not, that’s a quick fix repair technique
Efthreeoh
Hummer H3T
Eh, I don't think so. I think it is an assembly process. I'm just going by the pics posted in the several threads on the subject. It looks like to me the installation of the washer fluid reservoir is accomplished as such.
- the reservoir is a 2-part assembly; the reservoir cavity and the fill neck
- the fill neck snaps into the reservoir cavity
- at a specific assembly station, the cavity is snapped into mounts on the outside of the inner fender structure (prior to installation) of the outside fender
- the filler neck is then snapped into the reservoir cavity, but not bolted to the inner fender structure
- a zip tie is used to temporarily secure the filler neck so it is not accidentally knocked out of the reservoir opening it snaps into until the filler neck is bolted into place
- at a later assembly station, a line tech installs the bolt to the inner fender structure that mechanically affixes the filler neck to the inner fender. The tie wrap is not removed (BFD)
If one looks closely, there is a mounting tab on the inner fender that supports the filler neck from underneath. The tie wrap doesn't seem under any serious tension to act as a mechanical attachment point. I'd bet that the issue of filler necks de-attaching from the reservoir prior to bolting into place was round-tabled by the Bronco assembly personnel and the tie wrap was the solution devised to solve the issue.
But I'm a Ford apologist. :cool:
JimmyG
Greg
Ann Arbor, Michigan
Fords and Cadillacs
It's called a hood 🤣🤣🤣
OMG I literally laughed out loud again. Y'all gotta stop this shit. My wife is making huge fun of me! And the purse comment earlier.... holy shit. I am dying here. #YesImA12yrOldchild
MyATV
ATL
I don't know who comes up with this stuff.
Ford Bronco Zip Tied Washer Bottle 1634994724361
JohnnyBronco
Pennsylania
X4
I wonder if there had been an Internet in the 50’s if we would have seen posts like: my washer fluid is in a plastic bag under the hood Of my T-bird WTF @ErnestR.Breech!
Mine in my 59 Edsel hangs under the dash between the pedals, you lucky SOB!
