Colorado WTB: Rampage 2-Door Soft Top
HeliPilot
Kenny
CT
2022 2.7L SAS
Rubber nut certs?? You mean for the install into the roll bar?? Mine are black
Metal…
well nuts, mine were rubber and brass. Same style that came with my mesh top.
Mscdman
P
Denver
OBX
Metal…
And did you use the riv nut tool to install the rubber certs?
EGSquatched
Central Ohio
23 2dr Base Squatch
Anyone got a discount code?
Mscdman
P
Denver
OBX
Not what was in my box. You definitely received rivnuts. I received well nuts.
I wonder if they changed to well nuts to protect the paint and prevent the riv nut from spinning/coming loose..
Did you still use the riv nut tool to install?
Wonder what else they changed. And which is better a riv nut or a well nut…
Mscdman
P
Denver
OBX
Does it say which M10 well nut you got? Which thread pitch? What length?
HeliPilot
Kenny
CT
2022 2.7L SAS
No, just thread the bolt and tighten. Problem was that they sent the riv nut bolt, and it was too short to reach the threaded portion of the well nut. Otherwise, very easy to use.
Mscdman
P
Denver
OBX
How did you solve the issue? Did you buy another bolt that was longer?
HeliPilot
Kenny
CT
2022 2.7L SAS
My instructions were relevant to the Riv Nut you received. So I do not have the info you are looking for. Except, M8 was the bolt size that threads into it.
Mscdman
P
Denver
OBX
Hmm. That’s odd. They sent you a m8 well nut, but the riv nut is m10
HeliPilot
Kenny
CT
2022 2.7L SAS
Not really, the well nut is thicker because of the rubber housing, so it’s what fits through and fills the hole and leaves enough room to both thread and collapse the rubber as you tighten without breaking the rubber. The RIV NUT needed to be an M10 to accomplish the same thing.
Mscdman
P
Denver
OBX
Well crap. I guess the m10 well nuts I ordered won’t fit then :(
HeliPilot
Kenny
CT
2022 2.7L SAS
They may…but they may also be too big. I’d either give them a shot, or return and order a kit that has multiple sizes. I’ve seen them on Amazon.
