WOLFBOX G900 Pro Firmware Update
WolfBox
Florent
LA
2021 2dr Bronco
This thread is for WOLFBOX G900 Pro firmware update. I'll upload the file or put the link for you to download the new firmware.
Please be aware: Updating the firmware is not necessary as long as the unit works fine.
Download
https://wolfbox.com/pages/firmware
The new firmware version number is 11.241113.0.0.30-A0, the main changes of this version are as follows:
  1. Reduce the probability of voice-activated false triggering;
  2. Solve the issue that after setting the speed unit as KM/H in APP, the speed unit in the video watermark is displayed as MPH;
  3. Modify the problem of Italian and Japanese font;
  4. Save the configuration after the angle adjustment of the rear cam in preview interface;
  5. Update the intelligent voice library.
Upgrade instructions:
  1. Copy the firmware file to the root directory of the SD card (the outermost).
  2. Insert SD card into the dash cam, then it recognizes the firmware and it will have an prompt, click to confirm, start upgrading.
  3. After the upgrade progress bar is completed, the dash cam will restart and turn on automatically, which means the upgrade is completed.
Note:
  1. Copying the firmware to the card separately to upgrade only for a single dash cam to update. The file will be automatically deleted after the completion of the firmware upgrade.
  2. You can join our FB group WOLFBOX Community for other models' firmware update.
WolfBox
WolfBox
Florent
LA
2021 2dr Bronco
The new firmware version number is 11.250102.0.0.31-A0, the main change of this version is:
  1. Fix resolution anomaly
Download
