Wolfbox Battery Drain Cause for Failed Update?
codeseven4918
Calgary
2021 Honda Accord 2.0
I’ve been getting an error the past few nights that my software update has been interrupted. I’m curious if my hardwired Wolfbox dash/rear cam could be the cause, I do have the parking monitor enabled. Has anyone else run into a similar issue?
The short answer is no - a dash cam won’t prevent a software update
A low charged battery will, though.
Try this:
Unplug the negative battery terminal for about 5 minutes
Reconnect the negative terminal
This reboots all the modules and computers in the Bronco
Use a trickle charger rated for AGM batteries:
Connect (+) to the (+) battery terminal
Connect (-) to either chassis ground or the side tab on the (-) battery terminal
DO NOT connect directly to the (-) battery post
The BMS system must see the charger and going directly to the (-) battery post will bypass it.
Let the battery trickle charge over night. Low battery voltage, or just the BMS thinking there is low battery voltage, can cause a lot of odd things to occur and this corrects for that possibility.
codeseven4918
codeseven4918
Calgary
Try this:
Thanks for the suggestion! I’ll have to go out and get a trickle charger.
