Wiring Upfitter Switch
alihenry87
Ali
Illinois
2024 Bronco
I was given some advice/guidance on wiring my IAG amber grille lights and want to just be sure I was given the right information. I have a 2024 Bronco Badlands and the grille lights were wired with fuse tap to upfitter switch #6.
Thank you for any help you provide.
Ford Bronco Wiring Upfitter Switch IMG_2581
Ford Bronco Wiring Upfitter Switch IMG_2580
KillerPenz
North East
I'm a bit confused, do you have the upfitter switches? Normally you'd just tie into one of the wires under the hood. Only reason to use a fuse tap is if you don't have switches and want something to turn on when the truck is on.
Ironcreek
Don
32.50722N x 110.92533W
2026 Raptor Avalanche
If you have the upfitter switches then wire directly to them
alihenry87
Ali
Illinois
2024 Bronco
I do have the upfitter switches. I was advised to do it this way so that I did not have to deal with the wiring, but I will take it apart and do it the correct way. Thank you for your guidance. Any good sources out there to learn how to do it the right way?
Thank you for your help.
swamp2
Accessing the upfitter wiring for front lights doesn't require any disassembly. There are just stub upfitter wires near your front drivers side firewall under the hood, ready to connect. You just make a patch wire to get to the correct switch and an extension to the new light.
alihenry87
Ali
Illinois
2024 Bronco
Thank you!
alihenry87
Ali
Illinois
2024 Bronco
I appreciate it! Thank you!
For a small load like Grill lights (I'm assuming these are like the small Raptor running lights or lit letters, not big behind-the-grill spotlights or anything) -- those things you are probably just gonna leave on all the time -- no issues wiring them up with an Add-a-tap like you have in your pic. You won't be able to turn them off without popping the hood to pull the fuse - but for small lights like that, generally, you just want them on all the time the vehicle is on anyway, and Fuse 6 will do exactly that. I wouldn't burn an upfitter switch for something like that, unless you specifically wanted the ability to shut them off and run dark.
AdamF@IAG
Adam
Maryland
iagoffroad.com
'22 Bronco Raptor, '21 Bronco 2 and 4 door, '24 Ranger Raptor
Like @Brian_B stated, if you just want them on with the lighting cicuit, this is how we instruct to wire them. If you want to be able to switch them on and off, use the upfitter.
Ford Bronco Wiring Upfitter Switch 1780487633933-2z
PoppaPops
Northeast, USA
2023 Bronco Sasquatch
Agree with above if you want the lights on any/all time Bronco is on ... i went a little different route and tied my grill lights to the headlights so they are on/off with the headlights
Used this adapter ... SPV Harness Parking/Headlight Connector Adapter ... install was pretty straight forward .. unplug the headlight plug (passenger side if i recall correctly - access under the hood) and plug the head, harness and aux lighting into the adapter ... the lights turn on and off with the headlights
just a thought . . . .
Ford Bronco Wiring Upfitter Switch Screenshot 2026-06-03 at 9.22.40 AM
