I need to run 10awg red and black wire from the Redarc in the rear cargo area to the RTT on the roof for 200w solar.
Im thinking the two options may be to drill through the MIC top with a grommet and RTV or run the wire through the cargo area drain plug under the car and up through the tailgate/water channel in the rear window. I was curious if theres any other External access points to the roof I may be missing?
The two limitations I'm running into is I can't run wire through the A pillars since I already have lights running through there and I also am really trying to avoid taking the 150lb tent and rack off. and I also cant remove the rear hard top panel since its supporting the RTT (using trailrax TRMR).
