Wiring Baja Designs Squadron LEDs
CO_wildtrak
Denver, CO
2022 Ford Bronco 2-Door Wildtrak Sasquatch
I’ve picked up a pair of Squadron Pro pod lights for my A pillar and plan to wire them into AUX switch 3.
unfortunately, when I opened the box I found that I don’t have the upfitter harness and splitter that comes with the BD Bronco kit. I’m trying to avoid outplaying another $65 for the wiring harness, so my question is:
Can I cut apart the standard wiring harness to make an DIY upfitter harness? Or is this a really bad idea?
thanks in advance!
Baja Designs
San Marcos
thanks in advance!
Ford Bronco Wiring Baja Designs Squadron LEDs 64-0117HarnessMods
You are going to cut right before the relay. Tie in both powers and both grounds. You are then able to connect them to the aux switches on the vehicle.
Best,
Brahian
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
thanks in advance!
You can modify the harness that came with it. Check out our site at www.4x4TruckLEDs.com next time you need lighting, we make it REALLY easy for everybody
Here is our a-pillar harness. All plug and play:
https://www.4x4truckleds.com/crystalux-a-pillar-wiring-harness-2x-wp-2-pin-connectors-baja-designs/
Ford Bronco Wiring Baja Designs Squadron LEDs 1673103818393
Ford Bronco Wiring Baja Designs Squadron LEDs 1673103821978
Ford Bronco Wiring Baja Designs Squadron LEDs 1673103825568
