Windshield washer not spraying
Johnson
Harold
2021 Bronco Big Bend 4 door
Pump runs, tank is full, but no fluid comes out. The tank was empty when delivered so I ASSUME the pump needs to be primed. The tank is mounted in a way that the pump is hidden and there are no connections in the outlet hose that are exposed. Anybody have any ideas? It should be a warranty issue but I would like to cure it myself.
I thought about taping a shop vac outlet hose to the tank inlet (they are about the same diameter and the pressure is low and should not hurt anything) and then running the pump in order to prime it.
BigD
Dan
San Diego, CA
Bronco FE 2 Door
I have the exact same problem. Did you find a solution?
Johnson
Harold
That one did not work. I also drilled a stopper and installed a small tight hose bib and connecting it to a faucet and that did not work either. The pump would grind but no water. A week later now and the button on the end of the stalk will now work sometimes but the other location on the stalk does not. The car will now have to go in but I have misgivings since it looks like the fender will have to be removed.
Bronco21fan
Angelo
NewJersey
Take it to the dealer so it is documented in the system and ford knows about it so it dose t happen to the rest of us still waiting for our broncos the hose could be pinched or blocked
Bronco21fan
Angelo
NewJersey
Easy fix. Found the hose disconnected under the cowl.
And the shitty quality control continues I’m telling you guys they are just rushing these things out the door and us the customers are going to suffer for it
Headsong
If only that were true after many of us wait 3-4 months on the dirt. No QC on them!
Kdk12
Ron
Cleveland, Ohio
Jeep Cherokee, Yamaha V-star Silverado
Remove the cowl cover passenger side lift up and you'll see the washer tubes.
Nice. Just a couple of screws, right? Just got back from her first ride...
Jerry
Oregon
1989 Jeep YJ, 2021 Bronco First Edition
Yes the hex heads
same issue here, sprayer has never worked. I removed the hex head but cant check all the lines without removing the wiper arms as well. Anyone know how to do that? I removed the nut but the arm still doesnt come off. I hate to take it to the dealer just cause it is not spraying. I dont drive much so it will be a while before it needs a service.
2Jeeps&PatriotX1
Denver, CO
I had this issue yesterday (10 degrees out) but it was due to the factory washer fluid being frozen at the sprayers’ lines. I have this same issue with my f150 too. Doesnt matter if you use deicer fluid or not, it freezes inside the tubes where they connect to the sprayers.
Fordmanbob
Bob
KS
2018 F150 4x4 supercrew, 2006 F350 4x4 superc.
When you run the pump.....does the fluid run on the ground?
Jerry
Oregon
No fluid on the ground.
