Windshield Light Bar Mount
JamesC
James
Dallas, TX
HJ45, URJ200, W463
Ryuk
PA
2021 Ford Ranger, 2023 Ford F-150
Bronc-O
Phoenix
2021 Lincoln Aviator
The video shows the wiring going to the passenger side. Did they also run wires to the driver side? It wouldn't be hard to extend it under the windshield header but just curious if Ford will already do that.
Passenger side only. I'm getting the pod lights, so dealer will extend a wire to the drivers side for the other light.
alexryer
Alex
Winchester, MA
2021 Bronco Black Diamond 4-Dr Soft Manual
I'm planning on this.
This type of roof light setup is exactly what I have been looking for! It looks like the Rigid 360 bracket is exactly 2.0"" wide, and the arms of the L bracket fit with a little shaving maybe in the crack around the cover. The question I have is do you have to mount the L bracket on top of the black plastic piece that retains the cosmetic cover? Also, how do you get power to the driver's side? I suppose you could run the wire over inside under the plastics? Really cool and I hope you follow up with more details. I prefer the look of a pair of spots rather than a full light bar.
The other thing I'm considering is Rigid SR-series 6" SAE fog lights mounted in the pockets of the modular bumper. I like a single row of amber backlight with powerful low fog lights and I think this would work. They are about 8.75" long end to end and there is a bracket you can buy that would make mounting them upside down on the bronco bolts pretty straightforward.
Dino357
Daniel
Queens NY
22 Ford Bronco Wild trac /95 Ford Bronco XLT 5.0
Was watching a video on removing the factory roof rack. Looks like the windshield frame mounting points would be perfect for a lightbar frame. I don’t want the roof rack, as i plan on top off most of the summer. Anyone seeing the aftermarket building anything like this?
Hi yeah Specialty Performance Parts has what your looking for plus with there products there's no spicing it's all plug and play.
Dino357
Daniel
Queens NY
They also have installation video step by step on U tube.
Dino357
Daniel
Queens NY
I think there's wires above where the vanity mirrors are
Dino357
Daniel
Queens NY
Yeah check out Rigid light bars mounting hardware, and Rough Country, & Specialty Performance Parts.
BroncoA512021
Long Island, NY
www.facebook.com
2021 Ford Bronco OBX
