Windshield Defect
Danzer
Stroppe
Derek
AZ
Navigator/Corvette
Stroppe
Ford Bronco Windshield Defect 7C8831A2-03D0-4191-94FD-81EA51CE15C8
There are lots of smudges from plastic protection film I’m assuming and marks from suction cups. Does anybody else have this issue and if so how did you remove it? I tried water/vinegar and IPA/water with no results. I’ve also used multiple cleaners and can’t this to come off. I thought it was on the inside of the glass but now I feel it’s between the two pieces of glass. It really shows up if the window starts to fog up like in the photo or if the sun hits it just right. We took it to the dealer and tried buffing it out but that did nothing. They’re going to order a new one and hopefully they’re not back ordered.
Jandsnagel
Jeffrey
Erie,PA
2018 Chrysler Pacifica 2016 Honda Civic Touring
Magic eraser?
Danzer
Danzer
Stroppe
Derek
AZ
Navigator/Corvette
Stroppe
Magic eraser?
I tried that with no luck also. After an hour of using different products I really feel it’s between the glass. I could try the sandpaper from the post above but I’d hate to put anymore money towards this when I think it should just be replaced.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
I think you're right. Windshields are made of 2 pieces of glass sandwiched around a sheet of plastic. There was probably an issue with the bonding process.
Neps
Floating off California
MX-5 30th, Focus EV, F150, Scout II (2)
If your Bronco has the sound reducing glass make sure that's what they replace it with.
Dealers and insurance are notorious for going with the less expensive replacement glass. I was surprised how much more the sound deadening glass costs, and it does make a difference (at least in my F150, not sure if you could tell in a Bronco?).
HotdogThud
mk6 gti, '21 MoarDoor
hit it with a claybar and a razor blade and see what happens
WuNgUn
Ontario Canada
2 door Squatched
Hmmm... I think I noticed "suction cup" rings on my windshield as well. I assumed the factory had something suctioned to the windshield for when they did a 63Km random test drive of my Bronco. 🤷
Haven't noticed it since...
Danzer
Danzer
Stroppe
Derek
AZ
Navigator/Corvette
Stroppe
We told the dealer we only want a factory windshield. I want it to say Bronco and everything. I’m even going to remove the Built In Michigan sticker off the old one so I can stick it back on or at least save it in the glovebox.
Danzer
Danzer
Stroppe
Derek
AZ
Navigator/Corvette
Stroppe
Hopefully yours cleaned up than. Ours definitely has not and you can really see it on cold mornings or when the sun shines directly on it at the right angle.
Jjt24
JJ
Toledo Ohio
Escape, Mustang
I haven't really been over to the glass cell line at my F150 plant but I'm pretty sure it uses suction cups to lift and install the glass.
WuNgUn
Ontario Canada
2 door Squatched
Ahh, yes! Of course!
With the snow/rain weather we've been having, it's no wonder I haven't noticed it lately.... It's likely gone 👍🏻
WuNgUn
Ontario Canada
2 door Squatched
Have to tried a glass polish? Auto Glym has a good one.
Danzer
Danzer
Stroppe
Derek
AZ
Navigator/Corvette
Stroppe
I have not but I’ll check that out. I was looking into getting a glass polish.
