Window Stuck and Inoperable
benmaser
Ben
Ford Bronco
Just started to have this problem on my 21 Badlands 4 door. Driver's window stuck in up position. Can't reset. Does not slightly open with door opening so gets stuck outside door trim when I close the door. I do hear a very faint click in the door when I actuate the window switch either up or down but no window movement. Door lock actuator on driver door works and all other windows work as normal. Have checked all fuses and made sure the door wiring harness is secure. Has anyone had any luck here?
