Window delay
flip
Phil
IN
www.ruxerparts.com
Fords
Guessing we’d have to go to a dealer to find out or is there no bulletin for this issue yet if that window button relearn doesn’t work?
for some, it seems to have worked. Wish I was one of them, tried like 10 times last night getting out to check every 2:(
If it doesn't work I'd try disconnecting the battery for about 10 min, hooking back up and checking to see if they've started working correctly, if not try the relearn. Still not working? Take to dealer and let them figure out why.
710-oil-614
Cal
Columbus, Ohio
2023 Maverick Tremor, 2010 Toyota Tacoma
Yep. Get used to "double clutching" your doors open. A slight pull to activate the window but not pull open the door and then a second pull once the window has dropped.
I went SAS so my 3, 5, and 7 year olds can't reach the handles.
bhb
N NJ
Same. There are other threads addressing dealer fixes (removing door panels to align the windows), but I’m not ready for that yet.
https://www.bronco6g.com/forum/threads/window-getting-caught-when-opening-door.24948/
