Window closing issue
Tadel001
Tim
Maryland
‘87 Defender 110 RHD
4 door badlands with mid-package… The rear passenger side door is having issues with the window. At first it wouldn’t close the last inch. Now it won’t retract and extend when you open/close the door. The impact is that the window does not seat in the seal but against the seal. I have 4K miles on the truck and this just started. Anyone else seen this? I unplugged and replugged the door power connector to see if that is an issue. I have done nothing with the truck that impact this, i.e. haven’t removed the door, haven’t messed with the settings, etc.
MN_OuterBanks
AW
Minnesota
2015 F150 SuperCrew
Check the manual for the learning process for the windows.
Theherofails
Thomas
Phoenix
Did you do the magic window reset?
Roll it all the way down and then keep holding for 3-4 seconds. Roll all the way up and keep holding for 3-4 seconds. Repeat twice within 30 seconds.
Werkedperformance
Philthy
www.instagram.com
Badlands 4dr 7MT
May need to increase holding time from3-4 to 10 seconds, I can’t recall how long ford wants. But everything just said otherwise
1975U15
2019 F-350 SD, 1975 Bronco
I’m worried about windows medium to long term. When I was younger when I slammed a car door my grandpa would say “It’s not a Chevy” Ha!
So I’m sensitive to door slamming. The doors are designed super light for obvious reasons. With window down seems like if someone slams light door, it could cause issues. I let the kids know it’s not a Chevy😆
VelocityBrew
Minnesota North Metro
22 Badlands, 20 Passport, 16 1190 Adventure
Never driven a Subaru, eh?
1975U15
Sure have. Got one of those low ground clearance edition😆 My boys but driven many times. Great car that I ask he not treat it like a Chevy.
Ford Bronco Window closing issue E992B756-765D-4523-9083-AB2EDAD94E87
1975U15
This is lowered 😉 that WRX is monster truck height.
If I had a dollar for every time he’s told me the car I bought is “monster truck” height🤷 Need coil overs dad. Coil over your own wrx….ha!
Only if wvmtneer was her to express his disappointment 😆😆
mattm54
Katonah, NY
None
I was having this issue and this method solved the problem (i did it three times and held down and up for 10 seconds). thanks for the tip!
BroncoDawg
Aaron
Atlanta
2010 Mustang GT, 2018 Kia Stinger
Bump! Can confirm this method just worked for me as well.
bigblueboing
Keith
Los Angeles.
Forester
Have you tried turning it on and off again.
