Will the slide out tailgate delete the storage cubby underneath it?
Mango&Moose
SE USA
Scion xB / Toyota Sienna. RIP my 96 Ranger Splash
If FoMoCo would have just given us a true drop down tailgate instead of coping Jeep's swinging tailgate, this would be a non-issue...... just saying
That'd be a bitch to lower and raise with a 100 lb tire/wheel on the back.
I do think a lid on the tailgate makes the most sense; extend sliding tailgate, raise lid, access underneath.
BroncoBuckaroo
Joe
Missouri
2017GT350-SOLD, 2013 Ford Edge, 1969 Torino Cobra
Last I heard it was bolted in. It's weight/load bearing so it has to be bolted in. I would think this loses the storage cubby and the cargo your downs. And it's already been started you can't fit the doors with it. I wanted it at first but I'll wait for a better solution.
I did some research on this, and posted on it earlier as far as will Doors fit..they will. I show pics of the doors fitting with the slideout and without. The problems is not will they fit, the problem is the door tie down straps, but I think I figured out a fairly easy solution.
My understanding is the slideout is bolted in with 2 side rails (that use the existing standard 4 tie downs locations on the cargo area floor with tie downs removed to leave bolt holes) and then a cover attaches to the side rails. From what I understand is that to access the cubby you must fully extend the slideout, and there are 4 new tie down mechanisms that screw through the cover (to hold it down) and are anchored into the side rails. You unscrew or unclip ( I don't know which ) the plastic cover that conceals the 4 tie down bolts and remove and the cover comes off. Kinda awkward, be better with a hinge but does give you access.
Here is my early post with pics
https://www.bronco6g.com/forum/thre...a-with-bronco-brand-manager.10599/post-394968
The Pope
Swing Away Spare Tire Holder (like all of the Jeep Off-Roaders running larger that factory tires are adding to their Jeeps.....)
Mango&Moose
SE USA
Good point, wasn't implied in the other post since the current setup is posted to the door.
amccue90
Andrew
Illinois
2021 Badlands
ok what I want to know, with a soft-top, and a slide out, and one of those fancy secure enclosures for the storage area that closes it off when the swing gate is closed:
can I take off the doors and store them and the enclosure top piece wedged between them in the cargo area?
even if they have to stick above the sports rail due to the added height of the slide-out and the enclosure top.
Cause that would be sweet because I want all of these things and think they might conflict with eachother.
Edit: Four door
Edit Again: forget the slide out, the rest then?
Used2jeep
Massachuvian
2007 Crown Vic P71
Of course it’s removable . It’ll probably be bolted in the corners where the d rings are that get removed to install this. I’m sure they will just come with longer bolts that go through a hole in the d ring. All I was saying is that they will make a permanent cubby to put the jack and tooling into. That cubby will be part of the tray assembly. No one is going to remove it once installed.
Maybe the front of the slider cabinet bolts to the back bolt studs for the rear seat.
Used2jeep
Massachuvian
2007 Crown Vic P71
Edit: Four door
Tetris?
amccue90
Andrew
Illinois
2021 Badlands
i'm an excellent real life application tetris guy.
in my head this works out. unless the enclosure thing makes the area too narrow for the doors. otherwise, I don't think i see a problem. But i'm just one tetris guy. We the forum, are many
poconochris
Pocono's PA
2017 Rav4
Well the jack is under there somewhere too, I can imagine changing a tire would be fun.
amccue90
Andrew
Illinois
2021 Badlands
In case you or anyone else was curious, I got an email from a completely random cargo enclosure company, that could hypothetically be, but probably isn't, working directly with Ford.
They said hypothetically if they did work with Ford, they would aim to design the enclosure to maximize and not disrupt the cargo space of any hypothetical vehicle. And if a vehicle could stow doors as designed, the company would in theory, be provided specifications from any random vehicle manufacturer in order to design the enclosure to be used in conjunction with the standard design functions of the vehicle. One such possible function being door storage in the cargo area.
Hypothetically. :giggle:
CyberVegas
Ali
Las Vegas
BRONCO
Will this make the floor level more even when the seats are folded down?
karguy08
VA
GT350
Has anyone heard recently when this tailgate accessory will be in production? Also, i thought i had seen pricing on it at one time (early B&P maybe?), but I forget what it was. For some reason I am expecting around $400; can anyone confirm?
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
It’s a figment of our imagination right now.
... kind of like the Bronco itself for many of us :unsure:
