WildTrak Soft Top Test Drive - Quick Thoughts.
Ksjrb03
Tx
F250
While I dislike the waviness, I do want the lift up rear. That's one of the thing I miss when my JLU is on a soft top vs my hard top.
I agree on paper. Have you tested it? I found it pretty worthless, doesn’t lift very much.
Ksjrb03
Tx
F250
I took a 4D WildTrak Soft Top out today for about half an hour, and here are my thoughts:
1) Overall: Loved it. It is a fantastic vehicle. It looks amazing. I am getting Rapid Red, and it was fantastic in person. The 4 door has perfect proportions....assuming Sasquatch package.
2) Interior: I liked the entire interior. I really think it is nearly perfect for what it is intended to be. It is roomy for my 6'1" 205lb frame. Tons of cargo space with the seats down. The entire interior feels like it is of high quality from a durability standpoint, and it is comfortable. This has been beaten to death, so I won't labor on the interior.
3) Driving impressions: The vehicle is awesome to drive...in one word: fun. I pulled out of the dealer lot and drove for a bit, then dropped the top into the half open position, and dropped the windows. Up to 77mph and it was pure pleasure. I can't ask for more. The only thing I dislike is the low end acceleration. 0-40 feels somewhat slow; there is a pedal lag. On the highway at speed it has PLENTY of power to pass at speed, but taking off is not great...don't pull out in busy traffic. I am hoping that it is limited through the break in period and that this improves.
4) Soft Top: I am glad I changed to the soft top. It is very good quality and looks great...except for those wavy windows. The buckles are not adjustable, so it can not be adjusted out...it is what it is. The fact that Ford allowed Webasto to supply these windows instead of mandating stiff windows like BesTop uses is beyond unbelievable. That said...the rest is very nice and usable. The cloth is great, the function up and down is great. It is solid...it's not going to leak. The top is very good except for that one piece.
If you thought the 2.7 was slow, the 2.3 is really a dog off the line. Found it strange that Bronco is so lethargic compared to the 3.5s we’ve had in expeditions and f150s.
Gamecock
Gamecock
I agree. It’s neat but won’t be used much… or worth giving up flat windows for.
Andrew_EOD
Andrew
Panama City
Ford Focus ST
I wonder if they will ever address the acceleration. Same engine in other trucks isn't a snail...
Spooled
Republic of Texas
Raptor, Model 3
I'm sure there is lots of torque truncation and torque reduction going on in the PCM. Stock calibration is meant to help the 10R60 live.
MDPensfan
Annapolis
2021 Jeep Gladiator
Was this the WildTrak at Apple Ford in Columbia?
VictoryLights
Pittsburgh
2018 Honda Pilot
Sheesh, if the V6 struggles in acceleration what’s the 4 going to do?
VictoryLights
Pittsburgh
2018 Honda Pilot
I would like it to live, so maybe I’ll leave it configured the way the professional engineers designed it.
VictoryLights
Pittsburgh
2018 Honda Pilot
I don't have the specs in front of me, but I recall the Bronco curb weight can vary significantly, with some upscale loaded 4-doors nearing 5000lbs.
On the other hand, the Ranger pickup that a lot of people say performs well with the 2.3L, tops out max at around 4400lbs, with some versions just under 4000lbs.
Basically you add 600 or up to 1000 extra pounds of weight to a vehicle, and there will be a performance impact.
I bet the 2.3L will prove a better performing power plant, for the lighter weight versions of the Bronco 2-door. If getting one of the more bloated weight 4-doors, I'd probably go for the 2.7 V6.
Yeah, I agree. It will probably adequate for a 2 door non-sas non-badlands.
Raptor911
Raptor911
Broadlands, VA
wait >> Webasto supplied the soft-top windows?
Raptor911
Raptor911
Broadlands, VA
could you tell us this dealer location?
2Jeeps&PatriotX1
Denver, CO
Not me. As a jeep owner it takes me all of 10 seconds to unzip 2 zippers in rear, lift the flap up onto the rollbar to load/unload my dog. I saw the soft top in person, I’ll never use the rear top lift. Would rather have straight clean windows.
Big Boss
Outer Heaven
Bronco Big Bend
How was the road noise with the soft top? As much as I dont want to change I am starting to consider it
Gamecock
Gamecock
I really did not think it was bad. I did drop it though before I went on the highway, so only had it up up to about 50mph, so jot sure above that how it was with the top up. I definitely didn’t find it objectionable. I was thinking I was really glad I switched through list of the ride.
