Wider wheel or negative offset looks on Outerbank
kkurni
WA
Mini Countryman
I am thinking to change the default wheel to add a wider looks or negative offset?
Where can I get this done?
Will this void the warranty?
BOLD Renegade93
Bossier City, LA
2021 Ford Bronco Black Diamond
You can get it done pretty much anywhere that sells them. If you have a Discount Tire, I'd recommend someone like them unless you have a local shop you like.
It won't void the warranty unless you go extreme with it and a suspension component gets messed up because of the work you had done. Something like premature wear on a control arm or similar
Toccoa
Isuzu Rodeo Sport
Zero offset is already a bit obnoxious with standard flares. I can't imagine a negative offset being a good thing. 😟
