Why did they engineer TWO different MIC tops!?
WuNgUn
Ontario Canada
2 door Squatched
  • Thread starter
  • Banned
  • #1
I mean, honestly. The 4 door has an extra, backseat panel which is removable. This could of been designed so BOTH 2 door and 4 door clam shells could of been IDENTICAL! I'm sure in every other facet, like size and mounting, they're identical?
But, instead, the middle section on the 4 door had to have some fancy zig-zag angle to it.
I'm sure there is some pencil pushing manager face-palming this obvious faux pa
WuNgUn
WuNgUn
Ontario Canada
2 door Squatched
  • Thread starter
  • Banned
  • #3
Not a possibility. The rear clamshell is much smaller on the 4 door (look at window length).
Good point...
I guess they could of compromised the 2 door window...?
It's probably a consideration they made in early design
Wide Open Roads
Stace
Massachusetts
'09 Outback, '57 Alfa Romeo Giulietta, '10 911 C2S
While the simplest solution is generally the best, some things are far more complex than they would appear from the outside. If there were a way to save a penny, they would have.
WuNgUn
WuNgUn
Ontario Canada
2 door Squatched
  • Thread starter
  • Banned
  • #5
This is true... I can't wait to find out where they DID cut corners!
Blitzjb
Joel
Long Island
2021 Ford Bronco OBX
Then it would be called a jeep!
Wide Open Roads
Stace
Massachusetts
Oh yeah, after whining about waiting months/years, most of us will eventually turn our complaints to the things we wish Ford did better.
swooshdave
Portland, Oregon
Mustang
Zero clue about even the simplest dimensions.
Rick Astley
Up Doug's ass
d
Because the 2-door incorporates a pair of cupholders to appease Bronco6G members and their impossible standards.
On the 4-door you have to throw your beverage into the side windows and lick it off, because every 4-door owner is a ginger and has no soul.
WyoBronc
Kerry
Wyoming
2021 Ranger, 2021 Bronco BB, 2006 Saturn Vue
That may be an option when the doors and top are on, but the window-licking-gingers would be shit out of luck with the doors removed. The littering fines would quickly add up and the environmentalists would have a conniption fit bearing witness to beverage vessels flying out of Broncos.
I think they’re supposed to dump their beverages into their all weather liquid entrapping floor mats, and then slurp up their beverages through extra long twisty twirly paint matching straws.
Edit: The antimatter blue straws really pop in the sun!
BroncMO
St. Louis
2015 Jeep Grand Cherokee
I would think they aren't identical?
