Why are 6 Auxiliary Switches needed?
cesarinho
Cesar
Katy, TX
Mustang
I'm not good with this stuff - will there be an easy way to hook up to a garage opener? Like mounting one in the box where there terminate and somehow triggering it every time the switch is flipped, no matter which way?
I'm hoping to turn one into a Garage door opener as well...Since Ford decided it's too fancy to be standard equipment and you need to upgrade to the Lux package to get one 🤦
Lakelife36
Ben
Interior of BC
So you can click each one to the ON position like a fucking fighter jet, of course.
I fully intend to do this every time
BroncoActual
2018 Ford F-150 Raptor
Most likely not without tearing down the overhead console and splicing into the wire at the switch. As others have said already in this post, the aux switches are wired to the engine compartment and to a panel in the passenger footwell (if like the Raptor). These are physically latching switches, so you wouldn't be able to make it trigger every time no matter which way. The best you'd be able to do would be to flip it 'ON' for a few seconds to activate the UGDO, then flip it back to 'OFF'. Otherwise, the UGDO would see the switch as being constantly pressed (I'm not sure what happens if you hold down the open button on your UGDO for a long period of time)
No momentary option through settings?
No, these are mechanically latching
Lakelife36
Ben
Interior of BC
Thanks!
TJconvert2.7
Can somebody answer a stupid question? What could you possibly need 6 auxiliary switches for. I get lights, but what else is there?
Light bar
Pod lights
Grille lights
AM fog lights
Roof rack lights
Rear spot lights
Winch?
MillerBuilt
Tony
Washington
Chevy 3500, Dodge 2500, F150, Mercedez E350
when cleared for takeoff.....hit switch 1.....afterburner soundtrack. Hit switch 2....Top Gun soundtrack.
Switch 3.....Elk Bugle. Switch 4.....Coyote predator call.
Lorenzo
Larry
Oakland, CA
Ford F150
The real question is:
Did Ford make it easy to route wires from these switches to under dash, past firewall, etc.
* With simple A-Pillar covers that are easy to remove and actually have space for wires....
BroncoActual
They're pre-wired to the engine compartment and passenger footwell
Texasgrillchef
Gary
Dallas, Tx
Bronco Badlands, Harley Trike, Mustang
I need one to turn on and off the CB/Ham radios, inverter, wheel lights, rock lights, pod lights, rear lights.
guerro
AZ
2023 Bronco Raptor
If your thread devolves into a meme war on the first page, you aren't going to get the answers you were looking for. LOL.
deejaybee
Danny
Tampa
WIl I need to use 1 switch for these or 4?
Ford Bronco Why are 6 Auxiliary Switches needed? 1612150110063
mdonathan56
2022 Bronco Bad,2016 Q5 TDI, 2009 Honda Element EX
Somebody had to do it. :cool:
Ford Bronco Why are 6 Auxiliary Switches needed? 1612154425062
