Which Fuse for "Remote-Amp" activation?
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Tired searching but could not find the specific answer.....help please? :)
I just need to know which fuse I should be tapping into to send the "remote" turn-on signal for my sub-amp.
I have an "add-a-fuse kit" that has a 15amp fuse in it - and I know to TAP either Ignition or ACC right? I'm not some pro when it comes to electronics and don't want to fry anything or drain my battery by choosing the wrong one.
Also - is there a Grommet on the passenger side I can use for routing my power cable for the amp? The drivers side seems "crowded" already.....I figure I can route my wiring harness for the SUB on the Drivers side AND the Power wire on the passenger. This way I get less of a chance of them being close to each other and causing any interference. THoughts?
Any help and guidance on this would be great! Thanks in advance!!!!! :cool: 🖖
thepear
Ford Bronco 4 Door
