Wheels and tire shipping help!
thenewjs
Archie
Braptor
Just tried a quote on shipnex. Over a $1000 fuel surcharge!
112 LBS. for one wheel and tire?
I ran one for a set of 4 at 80lbs each 24x24x15. got ground for less that $500
shipped from Houston to dc
Ford Bronco Wheels and tire shipping help! Screen Shot 2022-09-16 at 11.38.07 AM
Hblhtx
Hunter
Houston
I put 70 lbs in for the weight but once I put in dimensions for box it changes the weight. Tires are 32” diameter and 10” width so did dimensions of 36x36x12 and that is what populates.
thenewjs
Archie
Braptor
I changed it to 70lbs 35x35x12
Ford Bronco Wheels and tire shipping help! Screen Shot 2022-09-16 at 12.12.57 PM
When I shipped, I didn't ship in a square box, I wrapped the wheels in cardboard. So I was left with round packages. that should bring your dimensions down. You will have to break down a box and wrap it tightly around the the wheel and tires. Im assuming the the tires are mounted to the wheels?
Hblhtx
Hunter
Houston
Yes still mounted. You didn’t have any issues with damage doing it that way?
thenewjs
Archie
Braptor
Never!!!!!!
Since the cardboard is taped to the tires, they don't move within the box.
For good cardboard I would use either a tv box or got to a rim shop and see if they had any boxes for 26" rims. Wrap the wheels tight with a ton of clear shipping tape and Ive never had a problem.
Just make sure the entire wheel and tire is encased in cardboard.
BroncoAZ
Mitch
There is no difference in the rate for a round package, they square out the measurements, so probably 33x33x11 for what the OP described. The tire doesn’t need to be encased in cardboard, just the wheel face needs cardboard for protection. New tires are shipped bare with some plastic wrap over a shipping label.
I really doubt shipping mounted wheels and tires is cost effective for takeoffs, just find some within driving distance.
