Wheel Liner Retainer Clips - REPLACEMENT
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Darcyjs14
D’Arcy
Seattle
1970 Ford F250 Camper Special 4spd
Man, the supply chain for this stuff stinks. It’s 2 months later and this is unavailable. Sure, there are alternatives but this 50 pack was a good deal.
redone17
redone17
Cold Spring, NY
I’m sure there are another “brand” that are similar if not the same. I have a few packs left, but after doing catch can, suspension, tail lights, etc. These things are necessary to have around.
zuke
Stafford VA
Clips and Fasteners is my go to for this kind of thing, If you have the factory part number, you can put that in the search box, and they'll give you the clip they have that matches...
I Just put in the JKS Max Tire Clearance Kit on my Bronco last weekend, and replaced all the factory retainers with these retainers from them, and they worked perfectly securing my inner fenders.
BayStaird
United States of America
2022 Bronco Wildtrak Sasquatch 2.7L V6 - Velocity
I wish there was a better option that is metal.
I'm installing mud flaps and while the bracket does the heavy lifting the last retention point is the one of these furthest in. Just don't trust it. 🤷‍♂️
Ground_zero298
Scs michigan
What kind of who do wee woo witch craft are those black things? Looks like the mounting bolts on a jeep.
Ford Bronco Wheel Liner Retainer Clips - REPLACEMENT 111F3A9E-D576-4EE7-87DA-1B3B72573962
Dwadeuru10
Derrick
Herriman, UT
Hyundai Sonata, Santa Fe
This was my issue installing my mud flaps. I checked it a few days later and that inside fastener had fallen off. When I tried to put another one in, I could never get it secured as if the holes didn't line up quite perfectly. Since I plan to remove the mud flaps when I off-road, I've been looking for a fastener that is a little more reliable, but haven't found anything yet.
redone17
redone17
Cold Spring, NY
The one I linked above is a bit wider.
There is also this thread - that uses the flat head version. which is even wider.
https://www.bronco6g.com/forum/thre...nder-liners-by-using-replacement-clips.66251/
