What part/accessory are you looking for that a company has not made?
gtabert
Greg
Woodstock, IL
'18 gt350r / '65 f100 / '99 Silverado / '15 VW TDI
I guess like everything read on this site there are those who have problems and negative results with products reviewed. I always find it odd, every review is full of good results and bad, this makes it hard to make an educated decision based on those reviews. If I were to believe all of them I'd have no vendor sourced product on my Bronco. It takes a leap of faith to move forward with any accessory. I'm in need of new tires, after reading countless posts, so many pro's and con's with every tire review out there, I'll throw a dart and see where it lands.
I've had no problems with my install of the MCL-6, works flawlessly. As for fitment, it clearly states it will not fit when you have the insulator pad under the hood. I took the time to carefully layout the point it hits the pad, carefully trim img it filling in any voids, it looks factory correct, hood closes fine.
mikec426
Russellville, AR
22 4dr Sqtch, 20 Triumph Tiger Rally, '04 Yam FZ1
Good to know, I canā€™t have that another question what kind of material is it is it rubbery or harder plastic?
Sort of rubbery. Very flexible stuff.
BCKMRKR
James
NorCal
'22 Wildtrak 2-Door, '19 Miata, '15 M235i
Mostly convenience items:
1) A simple plastic hook that snaps onto the rear seat (child seat anchors) so you could hang grocery bags for trip home.
2) Also some sort of hook or at least cover for the rear cargo area holes where (I believe) the soft top mechanism bolts to.
3)Also some cool (body color) billet ā€œBronco boltsā€ to insert into all the threaded holes exposed when top is removed
4) A reasonably priced ā€œD pillar brace that will fit the existing holes already there.
5) A simple bracket to mount 3rd brake light on spare tire lugs (have seen these for Jeep)
6) And, since youā€™re asking (DV8) šŸ˜‰ a removable front plate/grill on your OM front bumper (nice looking set up for sure) so those of us with adaptive CC donā€™t have to do the 42 step ACC bracket reloā€¦not confident it would work as well as factory location nor that it wouldnā€™t impact my factory warranty. Primary reason I ponied up the $$$ā€™s for the Lux pkg.
For #3 (bolts + tie-down capability):
https://www.rockworkx.com/collectio...screws-eight-piece-set?variant=41225460252868
Area51BS
Ron
Badlands non SAS 4dr 2.3
I believe you are asking about metal products. But I would like to see soft top rear side windows with large hidden zippers across the area where there are now clips. I like the soft top, not a fan of clips.
Rumbloki
Alton
ATX
ZR2, 1973 Mach 1
A bull bar for capable steel bumper that attaches to the bumper mounts
darkscion0
Canada
2016 Mini Cooper
I may have already said it in this thread a while ago, but...
Quick remove/disconnect mirrors.
The current mirrors are highly likely to get damaged on a tight trail, even when folded in. And when you fold them in, they unfold every time you open the door.
Zakm
Zak
Jacksonville, AR
A rear window for the soft top that unzips and rolls up for easier and better access to back.
Broncojbl
JBL
NYC
JCW Clubman, Wildtrak
This is more of a ford build request, but I want a way to fold in my mirrors from inside the car. Whether on a narrow trail or narrow garage, there are times you just need to do this on the fly.
Felix808
SRV CA
What 12 pages and not one mention of cup holders? You guys disappoint :sneaky:
& no I'm not looking for more cup holders ;)
CrazyPete
Buffalo, NY
2018 GMC Denali 2500HD Duramax
I read through this whole thread to see if anyone said this, otherwise i was gonna.
Totally agree. There's nothing really out there for the capable bumper. I have (had) no interest in the module bumper, though there are tons for that.
Hossamus Prime
Arkansas
www.instagram.com
21 BadSquatch,ā€˜21 ExplorerST , RIP 84 & 90 Broncos
35tires
'23 Bronco, '21 4Runner
one piece inside tailgate molle panel that doesn't require drilling. Doesn't exist in the market. I'd buy it instantly. It's the perfect spot for a molle panel, not many need a table, but the few that are out there are either two piece or require drilling.
nikkgmm
Nikk
Los Angeles
'21 Badlands
When my doors are off, I like to ride with my foot in the corner of the door well, slightly out. A foot step that goes into the bottom door hinge receptacle would be nice.
