What does Priority 19 mean?
connor'sdad
Louisiana
2022 F-250 Lariat, 1995 EB bronco and 2021 Bronco
anyone know what this indicates? i saw it on my order sheet.
Cappy
Cappy
North Texas
2021 Ford Ranger
Standard special order priority code. It just means that you're a custom build.
If it were a 01-09, that's a rushed order. Dealers typically keep 10-18 open for special circumstances, or if they need to bump something up.
19 - 99 is coded for dealer specific builds. 19 is "Custom Retail Order". No need to worry unless you see a code that has 50* and a notation. That typically means your order is being held back.
BrianBormes
Rapid City, SD
Powerstroke Bronco, Cummins Bronco, LS Bronco
19 is the lowest on the special orders, 10 is the highest.
Used2jeep
Massachuvian
2007 Crown Vic P71
Don't look outside but several large, black SUVs are converging on your residence. Don't argue, just go with the black suit clad gentlemen.
connor'sdad
Louisiana
well that sucks! ha
connor'sdad
Louisiana
well, hell, now it says 10 so that's good
BrianBormes
Rapid City, SD
well that sucks! ha
10-19 are customer orders. 10 best, 19 worst. 20+ are dealer stock orders.
Don't think on it too much, it probably wont make much of a difference if any because things will get built when parts are available, a priority code 19 black diamond could easily be built before a 10 wildtrack,
connor'sdad
Louisiana
Trying to be patient, but my current truck is a 2004 F 150 so i'm obviously ready for something new.
vrtical
Doug
GSMNP, TN
Fords
I still wondering IF Ford is going to honor that since well they are creating the shuffled deck after 3/19. I keep thinking in this scenario with the Bronco its worthless to the dealer but I dunno. It IS important on normal order/special order stuff.
XCR440
Nathan
Union, Iowa
Mustang GT, 22 Badlands 2 door
When converted, they drop in at 99 (not build-able) with random colors and base options. When the dealer makes changes to the order (your colors, options, etc) it saves it as a 19 (10-19 is build-able). Then it can be changed to 10 or leave it at 19, each dealer will be different.
