- Luis
- Oct 16, 2023
- 42
- 99
- 295
- Houston, Texas
- 2022 Ford Bronco
- Badlands
Convenience is the keyword. Underground Graphics is now offering pre-mixed solutions to make your installations easier. Yes, it is the same mix we talk about in every one of our YouTube installation videos, these are just made for you in a convenient 4oz bottle.
Two Solutions:
THE PREP
Our Alcohol & Water mix. A 1:10 ratio - 10% Iso. alcohol (70%), 90% water. Used to clean and prep the surface.
Directions for Use:
- Always use with clean twice-folded microfiber towel
- Do not use on hot surface. If surface is hot, allow to cool down before using solution.
Step 1 - Spray pre-mix onto twice-folded microfiber to pre-soak the towel surface
Step 2 - Clean install area, and all contaminated areas around install area
Step 3 - Wait for the cleaned area to be dry before Installation
Repeat steps 1 - 3 until all sections are cleaned
THE SLIDE
Our slip solution. Used for wet installs, particularly PPF, but can be used for wet install vinyl as well.
Directions for Use:
- For PPF use a rubber squeegee
- For Vinyl use a soft edge squeegee
- Shake well before use
Step 1 - Spray slip solution liberally onto the area of the vehicle where the vinyl is to be installed
Step 2 - Spray slip solution on the adhesive sides of the vinyl (for PPF spray both sides)
Step 3 - Place vinyl piece on the area to be installed and move into the correct fitting position
Step 4 - Using the appropriate squeegee, carefully push out the Slip Solution from underneath the vinyl layer. Use overlapping strokes with the squeegee to remove as much slip solution as possible.
Underground Graphics in a collaboration with Croftgate, USA is now offering you the best in vinyl wrap care products! With over 10 years of specializing in wrap care, we've made it as easy as possible for you to maintain the finish and longevity for years to come. The two signature products are a Sealant and a Cleaner. Both apply the same, see directions below, but both have different purposes. Both safe for matte and gloss finishes. 4oz bottles - spray head separate.
THE SEALANT.
First step and most important. Think of this as a barrier between the vinyl and the elements, similar to a ceramic coating, but not as permanent. To be used immediately after installation. Recommended application every 6-8 weeks or as needed.
THE CLEANER.
Basically, the maintenance spray. Think of this one as a quick detailer. Great to keep on hand for those quick touch ups, especially if you see any contaminants. We keep this and a clean microfiber towel on hand in each of our vehicles, …just in case.
Directions for Use:
- Use on clean wrap surfaces
- Do not use on hot surface. If surface and graphic is hot, allow to cool down before using sealant.
Step 1 - Spray Sealant onto twice-folded microfiber to pre-soak the towel surface
Step 2 - Spray Sealant onto one panel at a time and rub with the pre-soaked microfiber towel.
Step 3 - Use second clean microfiber towel to lightly buff surface
Repeat steps 1 - 3 until all sections are sealed
For more information or any questions, please don't hesitate to contact us
Phone: 713.783.4739
Email: [email protected]
