Vehicle Security/Anti-theft system
KJR50
K
SoCal
I'm not telling U.
Been reading discussions on accessories and easy access personal items walking away when parked, the usual advice is tie and lock everything down.
I’m curious if there’s any solution the oem/aftermarket is offering to convert the vehicle’s 360 system and assortment of sensors to turn on and record bursts of customizable length (10sec, 20sec, 30sec...) when motion is detected on a preset perimeter...and a warning decal like “Smile, you’re on camera.”
I know there are numerous aftermarket in-car add-on cameras but I’m thinking of a cleaner solution by utilizing what’s already on the vehicle.
SevenT
1970 U15 Sport Edition; 2021 AMB 4 Door Badlands
Ask an alarm installer if that is a possibility. Otherwise a locked vehicle is covered under insurance. I never leave valuables in my Bronco. (y)
Headsong
Why do I seem to recall something about a perimeter alarm system? Where did that go?
Skmac
Subaru Outback, Jaguar F-TYPE
Also anyone else think its a little short sighted that they made this a push to start. I know alot of guys when they go out on hikes will leave their keys locked in the glove compartment or somewhere like that so they dont have to worry about losing them on the trail. When it becomes a push to start anyone can just hop on in and start the car regardless where the key is located. I know this a unique situation but definitely seems like something they should of thought about.
SevenT
With push to start, the vehicle will not lock with the key in the vehicle. It locks the doors (w/proximity turned on) when the transponder is a certain distance from the vehicle. For hikers, they will have to figure out a place to carry the fob or a place away from the vehicle to hide/stow it. ;)
No jokes about prison purses on places to carry/stow the fob.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
With push to start, the vehicle will not lock with the key in the vehicle. It locks the doors when the transponder is a certain distance from the vehicle. For hikers, they will have to figure out a place to carry the fob or a place away from the vehicle to hide/stow it. ;)
Depending on how smart the vehicle is, and how it is set up to operate, you may be able to lock the vehicle while you're in it, get out, and then manually lock the driver's door.
By not utilizing the electric lock functionality it bypasses that safety feature.
(I do this pretty often in emergency vehicles that I have a spare key to, so I can secure them and walk away with them still running.)
SevenT
My practical experience is with the CFO's 2014 Fusion. No door lock knobs and if you try to lock the doors with the button, you can hear them unlock again.
Brownie
Maple Ridge, BC Canada
Bronco Badlands, 1981 Trans Am, 1972 Austin Mini
Actually you can lock the fob in the vehicle. Do it all the time.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
The Bronco looks like it has a mechanical lock flipper, which gives me hope.
Ford Bronco Vehicle Security/Anti-theft system preproduction-4-door-bronco 3
Raptor.Tremor.Bronco
Miami, FL
2021 Bronco Wildtrak, 2014 Raptor, 2020 Tremor
I'm not a fan of security systems. My new Ford Tremor was recently broken into and it was super close to being stolen. With modern fords you can get inside and get the door keypad code off the Fuse panel then take the car out of security mode which allows them to re program a key on the spot. In my case they failed at the last step, I think because its a 2020 and they couldn't program it yet. To prevent this from happening again built a shield to block my horn from being unplugged like they did and had a ravelco system installed. Its basically a plug that you stick anywhere in the vehicle that doesn't let the vehicle be started in any way. Its worth every bit of the $500 it cost me. It looks like on the bronco the horn is located inside the fender so it can't be tampered with easily, a louder horn would be great security.
KJR50
KJR50
K
SoCal
I'm not telling U.
Alarm system is just more noise and limited what it does, where bystanders usually just ignore. Pervs can still grab and run, like removing something bolted to the outside like fuel jugs or gears. They will get away with whatever they're willing to risk. Videos will be another level of security, ability to share with local area law enforcement, insurance, club/forum/board.
da_jokker
Jeep Wrangler JKUR
Yeah I was counting on this...but nobody talks about it so I worry it is not even "available" anymore.
Of course it could have been a piece of junk.
mdk100
Los Angeles
Porsche 911, Cayenne, BMW X3e, 2 door BaseSquatch
Old thread, but I have a lot of questions about theft and security. Not wanting to start squabbles about location, but I’m worried about everything that’s been discussed already. I’ll likely leave the top off or have a soft top on. But I’ve had doors stolen off a Jeep parked in my driveway.
Someone referred to this for ignition cut out, but I have no experience:
https://nohotwire.com/anti-theft-protection-for-jeeps/
I’ve seen these for Jeep doors, but it’s not clear if something similar could be made for the Bronco:
https://www.justforjeeps.com/82215100-82215101.html
There’s also the “perimeter alarm” in the accessory list, but I can’t find anything about it. Does anyone know anything about this alarm or have any experience with these other products?
AcesandEights
Ace!
Oregon
DR650
Ford is offering certain models with a 7-MT security device. You can opt for it, but late availability with the 2.7 or Sasquatch.
