Using upper dash USB port to run Android Auto?
Aonarch
Jack Hoff
MT
‘23 Bronco OBX 2DR Lux 2.7, ‘24 V60 Polestar
Mine works over Bluetooth, it also automagically turns on WiFi on the phone, must need more bandwidth...
Android Auto wireless uses wifi.
Mkohler30
Mkohler30
2024 Bronco
It's all up to date and yes I do that and select my phone but that is when it tells me to plug it in
Mkohler30
Mkohler30
2024 Bronco
Maybe I just need to get a new phone and then it would work wirelessly
Mkohler30
Mkohler30
2024 Bronco
After some searching I guess my phone is not compatible with wireless android auto.....going to get a new phone
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
I don't know if you tried this.
On Sync, go to Settings->Connections->Wireless App Projection
Make sure it's turned on
Make sure your phone's wifi can connect to the Network
You may have to Show Password and input it into your phone
Mkohler30
Mkohler30
2024 Bronco
I'll try that
Roberharrison
Rob
Chev silverado, 74 wagoneer
From my understanding you have to be plugged in to the vehicle to use Android Auto.....it doesn't work over Bluetooth
It works over Bluetooth
Mkohler30
Mkohler30
2024 Bronco
Well after much research I have come to the realization that my phone is too old so off to get a new one
