Using smaller wheels/tires on Black Diamond
silver bullet
Alan
Chesapeake, VA
2023 Bronco Black Diamond
This will probably sound odd to most of you. I put a set of 16" base wheels and tires on my Black Diamond, I have set the tire circumference to 2396mm. My issue is clearing the DTC (160) and the 4x4 warning light coming on. I reset the PCM relearn, but it has a manual transmission so there is not an ATC module to reset, for this vehicle, will that be the AWD module instead?
Thanks,
Alan
