- Aug 28, 2026
- 1
- 1
- 0
- massachusetts
- Traverse
- Black Diamond
Hi all! I’ve been reading through posts here for a while, but finally joined as my search for a pre-owned Bronco has officially started.
I’m primarily looking for a 2dr 7MT, but I’m also considering a 4dr if the right one comes along, probably in the $30K range. Here in the Northeast I’ve seen listings with anywhere from 40K to 125K miles, with asking prices often only a few thousand dollars apart depending on trim/options.
I’ve also come across a few with limited service history. On one side, that could simply mean the vehicle didn’t need any warranty work. On the other, it makes me wonder whether routine maintenance (particularly oil changes) was done consistently.
For those of you who have owned these for a while, what would you specifically look for when shopping used? Is there a mileage point where you’d simply walk away, assuming the price isn’t significantly lower? Would you consider a higher mileage Bronco if it had excellent maintenance records?
And for the 7MT specifically, is there anything beyond the known transmission grinding/TSB that you would consider a major issue?
I’m also debating an extended warranty, so I’m curious how much age/mileage would factor into that decision.
Appreciate any advice as there aren’t a ton of these available around here, so I’m trying to figure out where the sweet spot is between mileage, condition, options and price.
