Turn off-road third brake light install
bellboyfab
So-cal
‘22Bronco ‘93 C3500
This is gonna be a general walkthrough on the install and concerns with the Turn off-road third brake/chase light combo.
First is the size comparison of the OEM brake light (non raptor).
Ford Bronco Turn off-road third brake light install IMG_5551
The tools needed to complete the basics of the install are
•10mm socket
•1/2in socket
•4mm Allen wrench
•Ford torx wrench
•T25 torx wrench
Start by removing the access panel on inside of the tailgate and unplug the wires for the brake light and rear view camera. Squeeze the tabs on the plastic retainer for the rubber grommet and push out.
Ford Bronco Turn off-road third brake light install IMG_5550
Remove the spare tire. Then remove the 7 1/2in bolts holding the spare tire carrier to the vehicle. Use the Ford Torx wrench to remove the third brake light from the carrier. Now you can either cut the leading to the third brake light or use the T25 Torx to remove the 8 screws holding the assembly together and simply unplug the light.
Ford Bronco Turn off-road third brake light install IMG_5552
Now you can start the assembly of the new brackets using the supplied hardware.
First attach the bottom bracket to the tire carrier using the 4mm Allen head bolts and 4 washers. At this point I would recommend fitting the carrier back on the vehicle. If you aren’t using a reinforcement plate that spaces the carrier from the tailgate you might want to either place some padding or shave down the bottom of the bracket to keep it from impacting the tailgate.
Ford Bronco Turn off-road third brake light install IMG_5554
Even when adjusted as much as possible the bracket will still wobble and make contact with the tailgate when simply closing it.
Ford Bronco Turn off-road third brake light install IMG_5555
Now you can attach the light and bracket combo to the top of the first bracket using the last 3 4mm Allen head bolts and washers, before tightening make sure to adjust for your tire size. If running the stock black steelies and general grabbers the adjustments will be almost bottomed out. Now just run the included harness down the channel is the bottom bracket and attach ground wire to the back of the light housing.
Ford Bronco Turn off-road third brake light install IMG_5557
BadlandsGrizzly
Can you take some pictures of it illuminated during the day and night? I can’t find anything that shows it
Nanook
Jonathan
Raptor, Bronco, Galaxie, Ducati Streetfighter V4S
Concerned about it rubbing on the tailgate as well.
Did you run it to one of your aux switches for the chase lights?
I would also like to see it illuminated. 🍻
Honkman
J
Tennessee
2023 Bronco, Outer Banks, 4 Door
I want this thing so badly, but it’s so damn expensive. I’m not sure how it could be worth the $400 price tag, but I’m subscribed. I’d like to see the illuminated pictures.
Thanks for posting!
Cortez
Dallas, TX
24 BB 2DR, 75 F-150, HD EVO 96" S&S
Following, interested in purchasing but curious if the yellow chase is all the time or if you can connect it to the AUX, how bright the reverse is bc planning on swapping bulbs to something brighter but won't if this works well enough
Interested in this, but I've held off since it's pretty pricey and I don't know what LEDs are in it. If it had premium LEDs it would be one thing, but I don't know...
Coronabronco
Julio
Miami
Bronco Badlands
They use Baja designs. Also has anyone installed their flasher module?? Just received but not sure if I’m supposed to tap into the harness
Ford Bronco Turn off-road third brake light install IMG_1068
derichio02
Bo
Southern California
Bronco Badlands, Maverick, Tesla M3, F250 Tremor
Old thread but I ordered this while it was on sale.
Posting because I have a tip. Remove the bumpers from the old 3rd brake light and epoxy or 3M them to the new 3rd brake light. This helped with the shake and also with wiper clearance. *Also, that’s not a scratch beneath the bumper. It’s the reflection from the holes in the mount lol
Ford Bronco Turn off-road third brake light install IMG_5487
Ford Bronco Turn off-road third brake light install IMG_5489
Ford Bronco Turn off-road third brake light install IMG_5488
BattBronco35
Daniel
Southern California
2023 Bronco Badlands (2 Door)
I installed mine a few weeks ago and this is a brilliant idea. I see it scraping the area it's leaning on already so I will definitely have to do this.
derichio02
Bo
Southern California
I’m getting hyper flashing of the turn signal inside my vehicle after installing this with the harness. It does not happen to the actual light but just the indicator inside. Has anyone experienced this? I have the LED tail lights of that matters and using the plug and play harness from Turn
1st7MT
Jared
LI NY
Commenting just to stay informed. Purchased this recently
